Installing Optical SPDIF Port
Currently Active Users: 2049
Discussions: 200,897, Posts: 2,378,796, Members: 246,267
Old November 2nd, 2009, 01:21 PM   Digg it!   #1 (permalink)
Does anyone know how to install a digital optical (TOSLINK) port? Here's what I'm wanting to do:
I have a device with a SPDIF (coaxial) line-in; I would like to replace the coaxial with an optical port. Does anyone have any clue as to how to do this.
Please do not mention external converters, I know that it is possible to buy an external SPDIF converter.
othland is offline   Reply With Quote
Old November 2nd, 2009, 04:50 PM     #2 (permalink)
Light to Counter the Dim
MTAtech's Avatar
Send a message via AIM to MTAtech Send a message via Yahoo to MTAtech
One is electrical, the other is optical. You will need a device that accepts both, such as an AV receiver.
"The Bill of Rights is my Patriot Act."
MTAtech is online now   Reply With Quote
Old November 2nd, 2009, 05:21 PM     #3 (permalink)
"I have a device with a SPDIF (coaxial) line-in..."
To the best of my knowledge there is no difference between SPDIF coaxial, and SPDIF TOSLINK other than the connection type. So I would assume that the device would be able to decode a digital signal whether it came over Coaxial or Optical. Is there anything which prevents me from swapping a coaxial input with a TOSLINK input?
If so, what?
Old November 2nd, 2009, 06:44 PM     #4 (permalink)
MTAtech's Avatar
If so, what?
Huh? A coax cable is an electrical cable that transmits an electrical signal. A Toslink cable transmits a beam of light. They are not the same or interchangeable. Some devices, such as DVD players, have a digital coax or a Toslink optical connection for digital audio. Some players have both.
What device do you have that you want to accept digital audio into?
Old November 2nd, 2009, 09:55 PM     #5 (permalink)
I want to install it into a receiver. The receiver has a digital-to-analog converter (DAC), but only has a coaxial input, no TOSLINK.
"There are no differences between the signals transmitted over optical or coaxial S/PDIF connectors—both carry exactly the same information."
Source: Wikipedia article: S/PDIF
Old November 2nd, 2009, 10:50 PM     #6 (permalink)
MTAtech's Avatar
Read the next sentence from your source:
Selection of one over the other rests mainly on the availability of appropriate connectors on the chosen equipment and the preference and convenience of the user.
Yes, they both carry the same information and in the same format but one is electrical and the other is optical (light.) There is no way of making the light that comes out of a fiber cable go into a port that is expecting an electrical signal.
Saying that, you need a device that converts the signals from optical to electrical, such as this device.
Old November 3rd, 2009, 01:58 AM     #7 (permalink)
Yes, well, the light which comes out of an optical cable is eventually converted an electrical impulse.
SOURCE > CABLE > PORT > DAC > AMP > OUTPUT
Indeed, if sound is coming out of a speaker, ultimately all the contributing sound sources are converted into the same sort of electrical impulse as every other source. Digital feeds must be converted to analog by a DAC, and it is the job of the port to send the information from an optical line to the DAC as an electrical impulse. Because TOSLINK and Coaxial S/PDIF carry the same information a single DAC can be, and almost always is, used to convert the digital signal into an analog one.
Obviously, one cannot hook up an optical cable to a device without an optical port. That is why this post is titled, “Installing an Optical SPDIF Port,” and the first line reads, “Does anyone know how to install a digital optical (TOSLINK) port?” Where did you get the idea that I was talking about ramming an optical cable into a coaxial port?
I am amazed that this conversation has degenerated in such a way, and it’s probably best to just let the subject drop. For the record: I was looking for advice about how to attach a TOSLINK port to the internal circuitry of a receiver which already converts S/PDIF.
Thank you for your time, but I suspect that I will do better to simply wing it on my own.
Old November 3rd, 2009, 05:11 AM     #8 (permalink)
bigBonehead's Avatar
AMF...
Wisdom comes with age, but sometimes age comes alone...
bigBonehead is offline   Reply With Quote
Old November 3rd, 2009, 06:43 AM     #9 (permalink)
PC Upgrade Procrastinator
ShyguyXPC's Avatar
LOL, had to look up and see what that was short for.
Old November 3rd, 2009, 06:53 AM     #10 (permalink)
MTAtech's Avatar
Since that's what I did (see below), you could just say, 'thank you.'
From my post above:
I don't know what AMF means either.
Recording from Optical or SPDIF Audigy2 Inputs yardbird Multimedia and Audio 1 February 9th, 2004 02:22 PM
SPDIF MitaDC Multimedia and Audio 2 October 4th, 2003 08:09 PM
Installing printer on Netgear FM114P port? JohnBrown3 Networking and Internet 6 September 3rd, 2003 11:35 PM
spdif port for mobo jak General Tech Discussion 1 December 29th, 2002 03:12 AM
spdif jak Multimedia and Audio 9 November 28th, 2001 11:09 PM
Is It Just Me? (2778)
Foreign voltage (5)
A good PSU? (9)
California Passes Anti-Flat-HDTV Le.. (38)
Fox uses old news clips to inflate .. (33)
Print spooler problem (5)
Dept. of HS: NSA 'Helped' Develop V.. (11)
EVGA 9800 gtx help with finding a g.. (5)
Mysterious Boot manager (9)
Ideal cheap graph card for PC-Gamin.. (12)
New Build the Montior is blank (8)
8800 GT 512 and 9800 GT 512 SLI (12)
Foreign voltage (5)
hybernate option (2)
A good PSU? (9)
blender help (2)
Hard drive freezes boot (1)
Dept. of HS: NSA 'Helped' Develop Vis.. (11)
System recovery disk maker (2)
Like New Wacom 12x19 Intuos 3 + Grip .. (1)
windows 7 internet problem (3)
EVGA 9800 gtx help with finding a goo.. (5)
Skillsoft Network+ Study Software Que.. (8)
Ideal cheap graph card for PC-Gaming? (12)
Internet very slow since updating AVG.. (13)
Divx for vob to mkv (0)
Help:Cant play MP3 burnt CDs on my Ch.. (5)
XP Pro freezes on HP Media Center pc (0)
