Results 1 to 7 of 7
    Jul 2009
    San Diego
    117
    Uninstall Default Device
    I resently put a modem in my computer (XP PRO) so I could fax things, but right after I started having problems with sound in certain applications. I uninstalled the modem and removed it from my computer, but it's still showing up as a sound playback device in my control panels and I'm still having problems. Any ideas?
    Dec 2008
    East Chamunga
    2,362
    How about a system restore?
    ◄ it is what it is ►
    Jul 2009
    San Diego
    117
    I think system restore would be a last resort.
    Millwright stroyal's Avatar
    Dec 2002
    New Hampshire
    8,059
    System Restore only rolls back your system to an earlier date, why would it be the Last thing you try?
    The last thing would be a format and a reinstall, wouldn't it?
    Hard Sayin Not Knowin
    Jul 2009
    San Diego
    117
    You're right I was thinking reinstall, but I don't have a system restore partition anyway
    Dec 2002
    New Hampshire
    8,059
    Not a partition, but a restore point saved by Windows, unless it was turned off.
    It is on by default.
    Go to Start, Programs,Accessories, System Tools, System Restore.
    Dec 2008
    East Chamunga
    2,362
    That actually brings up a good point. I've seen a few Windows tweak sites that say turn off SR. After a few bad experiences with that, I no longer keep it entirely off. What I do instead is crank the size of the restore file to minimum on the recovery partition, leave it normal size on the partition I use for surfing, crank it up a few notches on my DAW drive, and turn it off on my external USB HD, which is only used for archives...
  1. Replies: 5
    Last Post: March 6th, 2011, 08:38 PM
  2. Uninstall AVG without uninstall.exe
    By draboo in forum General Tech Discussion
    Last Post: February 20th, 2010, 01:28 AM
  3. Please Help Uninstall
    By ryanredbaron in forum Linux and Unix
    Last Post: June 10th, 2005, 02:53 AM
  4. setting default network device for LAN?
    By Lonefox in forum Networking and Internet
    Last Post: October 14th, 2004, 05:04 PM
  5. How change lots of Windows default paths; how remove Wins default programs?
    By Wai_Wai in forum Applications and Operating Systems
    Last Post: July 24th, 2004, 02:36 PM
