Results 1 to 2 of 2
Thread: dvd replacement
    Jan 2010
    4
    dvd replacement
    Can I replace a dvd rom drive with a dvdrw drive?
    I already have a dvdrw drive as my second drive...The dvd rom died and I thought if I replace it with annother dvdrw I would be ok if my other dvdrw died!
    I have dimension e521 running vista premiun which I am about to upgrade to windows 7...
    Also...what size sata dvdrw should I get?
    Thanks...
    South Jersey
    11,368
    Hi, Suzanne:
    Yes, absolutely. Every DVD/RW drive can also read discs, obviously, so there's no problem having two DVD/RW drives. Here are the installation instructions for your system.
    All optical drives are the same size.
  1. Inspiron 1501 DVD Burner Replacement
    By butch81385 in forum General Tech Discussion
    Last Post: May 20th, 2009, 05:51 AM
  2. dvd shrink replacement
    By sr71000 in forum Multimedia and Audio
    Last Post: April 16th, 2006, 09:14 PM
  3. dvd rom replacement
    By flyguyspy in forum PC Modification
    Last Post: January 27th, 2006, 11:53 PM
  4. need replacement dvd-rom drive for vaio
    By randemar in forum Technical Support
    Last Post: April 5th, 2005, 06:21 PM
  5. APEX DVD warranty replacement
    By TOAD6147 in forum Multimedia and Audio
    Last Post: September 15th, 2003, 09:53 AM
