Results 1 to 6 of 6
    Member Gomar's Avatar
    Oct 2007
    NYC
    105
    Why is there no 144kbps?
    Why is there no 144kbps? It's incremented by 16, but jumps from 128 to 160 by 32. Only 2 rippers have 144kbps. One of them gave me an error.
    Also, it took much longer to convert from flac to mp3 than from wav. CDex, when set to rip to compressed file, creates a WAV first, then mp3 from it. Makes sense, as it saves time. However, if I were to rip to flac first, I'd have to then change the encoder to mp3.
    Thus, ripping to flac is a waste of time, not much space is saved as HDDs and DVDs are cheap.
    South Jersey
    11,368
    Are you using EAC? If not, what are you using?
    Oct 2007
    NYC
    105
    right in my post... CDex.I prefer 160 to 128, but if 144 were available, I'd use it. Seems 128 is the lowest setting to get decent quality sound.
    Dec 2008
    East Chamunga
    2,362
    Quote Originally Posted by Gomar View Post
    .flac uses lossless compression, its quality is the same as on a CD. MP3 uses lossy compression, so the quality will be worse even at 320Kbps.
    So, why are you looking for 144Kbps? if you are trying to save space on a portable player, then I recommend a VBR conversion with the low set to 128Kbps and the high set to 320kbps and a Q setting of around 2 or 3...
    Otherwise, .flac is much better sonically IMO
    ◄ it is what it is ►
    Ultimate Member ChoaticWhisper's Avatar
    Alabama
    1,327
    Audacity using the lame encoder will do 144 kbps BUT will only export 144 kbps at 24000Hz.
    Heres a few numbers
    Kbps - Hz - Enc Time - File Size
    144kbps-24000Hz-28 secs-3.45MB
    128kbps-44000Hz-27 secs-3.07MB
    160kbps-44000Hz-27 secs-3.84MB
    Btw it was mp3-mp3 conversion
    So I doesn't make sense to me.
    South Jersey
    11,368
    Actually, a lot lower than what most people consider decent quality.
