Results 1 to 10 of 10
    Jan 2010
    7
    No sound and unable to install ADI 198x Audio driver
    I own a Dell Dimension 8300 pc with Creative LAbs 5.1 Audigy2 Audio Card and Nvidia GeForce FX 5200 video card.
    I've installed the drivers for Creative Labs Sound Blaster Audigy2 drivers CD I got when I purchased this PC. I've also installed the latest patch/upgrade for this that I d/led from http://support.dell.com/support/dow...
    I've also installed all the drivers that came with the Dell Dimension 8300 Drivers CD Rom. Even the newest Nvidia video driver from nvidia's website - because the older driver from the Dell Drivers CDROM that came with my pc was giving me lots of serious problems with the BSOD and the "nav4_disp" file..And that newer Nvidia seemed to have fixed it - i.e. no more screen blackouts and BSODs referring to the "nav4_disp" file.
    There is however, an audio driver included with the cd-rom that I could not install. Its called the Analog Devices ADI 198x Integrated Audio driver, downloadable from http://support.dell.com/support/dow...
    Its name is also called SoundMax.
    Anyways, so everytime I try to install it with the Installshield Wizard, out pops the error message : "Driver not found! Reboot your system and run this setup again."
    I've tried running the setup again and again and rebooting again and again, but still no joy.
    I have no idea what is wrong, or what I can do to fix it. Whenever I play a video or a soundfile, there will just be no sound (although the programs for videos and music players appear to work fine with no error messages whatsoever).
    Even when Windows XP starts up, the start-up melody doesn't even play.
    And of course I've made sure my amps are switched on, and that the volume controls are all switched on and aren't muted, and that all the wires and connections are properly fitted, etc.. In fact I made sure no volume sources were muted. But still, no sound whatsoever.
    Can anyone tell me what's wrong???
    Nov 2006
    Portsmouth, UK
    4,159
    Well as you have an added soundcard you shouldn't need to instal the on-board sound drivers. Have you hooked your speakers up to the sound card?
    Have you gone into device manager and looked for any question marks?
    Jan 2010
    7
    Hi, my speaker to PC connections have stayed the same always. Its just that I wiped out my hard drive and reinstalled Windows XP plus the additional audio/video drivers 2 weeks ago because my computer crashed, and ever since then I've been unable to play any sounds on my computer. By the way my speakers are still working because when I switch them on and off, they still produce the same "popping" sound as they used to even before the PC had crashed on me 2 weeks ago.
    I've gone into Device Manager and the only things showing question marks are for my printer, scanner and PCI modem, because I hadn't reinstalled their drivers yet (no time you know... plus I want to fix the sound problem first).
    Now in Device Manager, I've gone into Sound, Video and Game controllers and found the following devices enabled :
    Audio Codecs
    Creative Audigy Audio Processer (WDM)
    Legacy Audio Drivers
    Legacy Video Capture Devices
    Media Control Devices
    Microsoft Kernel System Audio Device
    Microsoft Kernel Wave Audio Mixer
    Microsoft WINMM WDM Audio Compatibility Driver
    Video Codecs.
    From that list, the following devices do not come with any option to Enable/Disable :
    Audio Codecs
    Video Codecs.
    These same objects, I noticed before, were present even before I'd reinstalled the drivers for Creative Labs Audigy2 drivers... I wonder if they're causing the problem at all. Because if they are, I don't know what to do with them - there's no option to disable them!
    By the way I'm no techie and all I know is that in order to get a device working properly the drivers have to be installed!
    Nov 2006
    Portsmouth, UK
    4,159
    Okay have you gone to sound options in control panel and made the Creative card the default?
    Jan 2010
    7
    @ Aaron 8015 : It says there the default device for all options are SB Audigy (which is the Creative Labs one)...
    Dec 2008
    East Chamunga
    2,362
    What are the Volume sliders set to in the Audio Control Panel, and are there any Mute Boxes checked?
    ◄ it is what it is ►
    Jan 2010
    7
    @ bigBonehead : Vol. sliders are set to maximum. There aren't any mute boxes checked.
    Dec 2008
    East Chamunga
    2,362
    Sorry I didn't catch that in your first post. Download this driver: Creative Worldwide Support
    Un-install the Creative driver through the device manager, then re-boot. Cancel out any attempt by Windows to install the driver. Then double click the downloaded driver to install.
    EDIT/ Almost forgot... grab this and run the Registry Cleaner till it comes up with no issues. with all of your attempts at fixing the problem, it couldn't hurt: CCleaner - Home
    Jan 2010
    7
    I found this page on dell support website telling me the proper steps to reinstall windows xp... and I had to wipe out my hard disc and start from scratch again, follow the steps, and now the sound works fine on my computer. Apparently if you don't do the steps in the right order, this sort of problem can occur!
    @Bigbonehead : Thanks for your help!
    I guess your way might have worked too but I had already fixed the problem before reading your message.
    Cheers!
    Rachel
    Dec 2008
    East Chamunga
    2,362
    No worries! Glad you got it sussed out.
    Brian
  1. which sound driver i have to install
    By tetali_palreddy in forum Technical Support
    Last Post: January 23rd, 2009, 08:14 AM
  2. Replies: 0
    Last Post: December 14th, 2007, 01:13 PM
  3. Replies: 21
    Last Post: January 23rd, 2002, 08:39 PM
  4. Sound driver install problems
    By Philip1952 in forum Technical Support
    Last Post: December 19th, 2001, 08:06 AM
