hi,
I ve got an audio about 13 meg mp3
there must be some way of putting a photo on it
and getting it up to you tube...
any ideas how I do it ?
Printable View
hi,
use windows Movie maker, import the audio track, and then just import an image to the first frame.
I can't remember on Windows Movie Maker for Windows XP, but for Vista and Windows 7 if your using Windows Live Movie Maker, you Add a Photo or picture, then Add the Audio Track, and then on the Main Home Tab, there is an option for "Fit to Music", it basically duplicates the image for the length of the Audio track, once thats done, you can add credits if you wish, or simply save the project and/or Publish/Save the Movie in the video format of your choice that Movie Maker Supports.
With Windows Live Movie Maker, there is an option to Publish Movie, in which case it can Publish to Youtube if you need to.
see pic below:
