Results 1 to 6 of 6
    Mar 2010
    11
    voice recorder problem...help!
    hi guys, i knw dis has nuttin to do wit comps but i need some help with this. thank u very much
    ok...
    i have a sony mp3 voice recorder. it records well. when i playback the recorded sound/file, listening from the stereo jack thru headphones, there is no sound coming from the right side of the headphones. at first i thought the right ear headphone was faulty, so i used 2 more pairs of different headphones. same problem, right side no sound.
    i thought to myself theres no way all 3 of my headphones were faulty coz i tried the headphones on the comp, ipod & sound was comin from the right. also when i play the recorded file from the voice recorder on the computer (winamp), sound was comin from the right side speakers.
    so i thought the problem is comin from the voice recorder, that the sound playback cant go thru any headphones (to the right ear side).
    ive identified the problem, but can any1 tell me how to fix it & how dis thing happened? i bought my recorder from ebay with all the legit packaging & 1 year warranty. i have never misused this recorder such as dropping it etc.
    thank u for ur help...
    Dec 2008
    East Chamunga
    2,362
    It would help to know the model of the recorder... Does it even record in stereo?
    Can you transfer the file to the computer and see if it plays in stereo there?
    ◄ it is what it is ►
    Mar 2010
    11
    the recorder is a sony ux81 2gb. yes it duz record in stereo. yes i can transfer the file & play stereo in the pc (sound comin from left & right speakers). problem is about no sound comin from the right earphone when the earphone is plugged into the recorder for playback
    Dec 2008
    East Chamunga
    2,362
    IMO, you have a problem with this unit... If it's still under a warranty, get it fixed, or contact the seller from Ebay...
    Mar 2010
    11
    the warrany is for the US. im an australian in sydney:-(. o yeah i found out that the right side ear phones works if the plug is inserted halfway down the stereo jack of the mp3 voice recorder, dis goes for any headphones.
    Dec 2008
    East Chamunga
    2,362
    That's a normal short circuit of the stereo jack... The same procedure will produce the same effect on a good unit... As I stated above, try contacting the seller... If they are a member in good standing with Ebay, they should be willing to replace the unit. It is defective IMHO
    Good luck mate!
  1. Driver for Olympus Digital Voice Recorder
    By Cles in forum Applications and Operating Systems
    Last Post: February 18th, 2012, 04:30 PM
  2. Olympus VN-240PC Digital Voice Recorder drivers
    By Rico Mania in forum Technical Support
    Last Post: August 18th, 2010, 05:11 PM
  3. olympus digital voice recorder /ws-450s
    By FRANK MADIN in forum Technical Support
    Last Post: January 19th, 2010, 06:42 PM
  4. Olympus digital voice recorder - software
    By JuC in forum Multimedia and Audio
    Last Post: March 19th, 2009, 12:33 PM
  5. Voice Recorder… suggestions?
    By Blazer06 in forum IMO Community
    Last Post: July 27th, 2005, 12:12 AM
