April 3rd, 2010, 11:45 PM #1Junior Member
- Apr 2010
- 3
Front panel audio jack only plays sound in one speaker
The audio jack only produces sound through one speaker when the jack is fully inserted. If I "wiggle" the jack in a little at a time, I can get both speakers to play, but in poor quality. Any help to remedy this so I can get it back to playing sound in both speakers would be great! Thanks
April 4th, 2010, 05:07 PM #2
What happens when the back panel jack is used?
◄ it is what it is ►
April 5th, 2010, 02:28 AM #3Junior Member
- Apr 2010
- 3
The audio works great on the back panel. I use it for my speakers and I use the front panel for a headset. I could always get a splitter but if it's possible, I would really like to use the front panel due to the length on the cord I have to work with.
April 5th, 2010, 10:57 AM #4
Front panel jacks are prone to this sort of thing from different plugs being inserted and removed. I generally recommend not using them for this reason. My preference is to always use the jacks in the sound card, with stereo mini extension near my monitor for the headphones.
If cord length is an issue, the extensions are like $5, certainly cheaper than wearing out the jacks on your computer.
How to disable audio front panel from back panel
By osmith3 in forum Technical SupportReplies: 3Last Post: March 1st, 2009, 03:14 PM -
I Cant hook up my front panel audio and mic?
By Gordons in forum Multimedia and AudioReplies: 1Last Post: March 1st, 2009, 04:24 AM -
front audio panel molex
By Chapper in forum MotherboardsReplies: 6Last Post: November 27th, 2006, 10:39 PM -
Audigy 2 ZS Front Panel 1/4 Input Jack Problem
By skybolt_1 in forum Multimedia and AudioReplies: 3Last Post: June 21st, 2005, 04:14 PM -
Case front panel audio connectors ?
By Kimbo in forum Technical SupportReplies: 3Last Post: November 10th, 2003, 04:49 AM
Hello Friends, If you have missed your favourite tv shows or movie. Dont Worry, Enjoy Here: Game of Thrones Season 3 Episode 8 Mad Men Season 6 Episode 8 Revolution Episode 18 The Big C Season...
Rules of Engagement Season 7...
