Results 1 to 12 of 12
    May 2010
    5
    Laptop makes choppy noise while playing DVD
    Hi,
    my Dell Inspiron 1520 all of a sudden makes weird choppy, crackling noises while playing DVD's.
    Video is fine and when I play movies directly from my HDD, audio is fine too.
    Do I have to replace the optical drive?
    Thanks so much for any help!
    Karla
    ph34r t3h g04t Whir's Avatar
    Kingsford, MI
    29,231
    7
    Is it only when playing DVDs? For example, does it make the noises when reading a data CD?
    May 2010
    5
    Any DVD or CD with sound.
    Thanks!
    Kingsford, MI
    29,231
    7
    So the sound is coming through the speakers, not from the drive itself?
    May 2010
    5
    yes, I think so, but the noise is only when I play a CD or DVD not when I play music or movies from my hard drive
    Dec 2008
    East Chamunga
    2,362
    When was the last time you cleaned the Optical Drive? Walmart and other places sell disc drive cleaners... That may help. Also, have you gone to the Dell Support site and checked for updated firmware/software for the optical unit?
    ◄ it is what it is ►
    May 2010
    5
    I've cleaned the drive with compressed air, but it didn't make any difference.
    I will check the dell support later today for updates, thanks for that!
    The big mystery to me is just that the drive doesn't make any noise when copying a CD or playing a data CD, but only when audio is turned on...
    Dec 2008
    East Chamunga
    2,362
    The cleaner I referred to is not compressed air. It's a disc that has tiny brushes on it that actually wipes the laser...
    Are you talking about noise from the unit itself, or output through the speakers?
    May 2010
    5
    The problem is solved! I did a system restore today back to the day when the drive was running normally, maybe it was some kind of a software problem...?
    Anyway the noise is gone!
    I'll get one of the cleaning discs anyway, I never cleaned the laser before.
    Thanks for all your help here, I really appreciate it!
    Dec 2008
    East Chamunga
    2,362
    Great!
    Jun 2010
    Yea you get that allot when software is reading it wrong. Alnother alternative is to get a external DVD Copier of CD drive.
    www.riveraudiopro.co.uk
    Jun 2010
    re:LAPTOP makes choppy noise while playing DVD
    LAPTOP makes choppy noise while playing DVD, MAYbe your computer have something wrong.
    i can recommand several laptops for you.
    if you are interested in our products,you can get more details on our website :Glad wholesale, Buy Wholesale Price Products Direct from Chinese Wholesaler OR
    Online Shopping Direct from china: Laptops, Game Console, HDTVs & more - Wholesale Electronics made in China
    welcome you visit our website!
  1. Mouse makes scratchy noise over speakers
    By DCO in forum General Tech Discussion
    Last Post: January 20th, 2010, 03:48 AM
  2. Laptop to DVD for music playing purposes
    By K.B in forum Mobile Computing
    Last Post: May 24th, 2008, 10:09 AM
  3. Geforce FX5500 choppy graphics playing War Front Turning Point
    By wattoo in forum Graphics Cards and Displays
    Last Post: February 8th, 2007, 08:36 PM
  4. DVD playback choppy on Toshiba laptop
    By dface in forum Mobile Computing
    Last Post: February 18th, 2004, 02:59 AM
  5. MY fan makes noise!!
    By Creatures in forum General Tech Discussion
    Last Post: September 6th, 2002, 06:38 AM
