Thread: DVDR/Digi Recorder Setup
January 15th, 2011, 02:18 PM #1Junior Member
- Mar 2009
- 5
Hi
I'm trying to add a Liteon LVW5006 DVD Recorder to my current system. I'm running a Humax 9300T Digi Recorder and an ancient (but still very functional) Sony TV. The DVDR was setup with the TV before we went digital and worked fine.
Here's the problem: I've set up the connections as recommended by Humax for RF Cable connection:
A. . External aerial remains connected to the digibox
B. TV/VCR loop out of the digibox to aerial input of the DVDR
C. Aerial output of the DVDR to Aerial input of TV
Having done that, I can't tune the DVDR on the TV--AV just gives me snow--can't find a workable channel or test pattern to setup the DVDR or play DVDs--I'm assuming this is because the external aerial goes directly into the digibox, but stymied nevertheless. Is there something wrong with the way I've set it up or, alternatively, would a SCART connection from digibox to DVDR solve the problem. There's no SCART connection on the TV (I told you it was ancient).
Thanks in advance
new dvdr wont work
By sickmaggot in forum Technical SupportReplies: 0Last Post: August 7th, 2008, 09:55 AM -
DVDR Problems..please help
By simdawg in forum Multimedia and AudioReplies: 6Last Post: November 17th, 2006, 08:42 AM -
dvdr/rw question
By rockpile in forum Storage RelatedReplies: 3Last Post: November 12th, 2005, 10:31 AM -
help needed with dvd 2 dvdr
By nightscape in forum Multimedia and AudioReplies: 6Last Post: March 4th, 2004, 10:50 PM -
DVDR compatibility??
By Dazbo666 in forum Storage RelatedReplies: 1Last Post: December 25th, 2003, 09:15 PM
I suggest you to read this blog and take help of it: How to safely compress an oversized PST file Hope after reading this you would be able to reduce the size of your .pst file. Regards. :)
Weird sized Outlook.pst file?
