February 3rd, 2011, 08:18 PM #1Junior Member
- Feb 2011
- 1
Olympus Digital Voice Recorder Problem
I have an Olympus Digital Voice recorder WS 450S with the following issues:
1) It has two files on it totally less than 3 hours and yet when you try to record it says "memory full"
2) All the other Folders are empty
3) Plugging it into a Macbook - and doing Command I on the files shows them to have zero kilobytes. I drag them onto the desk top and they do not play.. though they do play if I listen to them directly from the Recorder when it is hand held.
4) Doing Command I on the whole mounted Recorder as it appears on the desk top confirms that the 1 gig disk is 'Full'
Can anyone make any suggestions to cure the problem?
Should I just reformat this device for?
Can I reformat it for a Mac ?
( like you can format a memory stick or flash drive for either PC or Mac)
All suggestions gratefully accepted
best
M S
Driver for Olympus Digital Voice Recorder
By Cles in forum Applications and Operating SystemsReplies: 29Last Post: February 18th, 2012, 04:30 PM -
olympus digital voice recorder ws-200s playback problems!!
By LAURASUE83 in forum Technical SupportReplies: 1Last Post: July 7th, 2011, 04:56 AM -
Olympus VN-240PC Digital Voice Recorder drivers
By Rico Mania in forum Technical SupportReplies: 20Last Post: August 18th, 2010, 05:11 PM -
olympus digital voice recorder /ws-450s
By FRANK MADIN in forum Technical SupportReplies: 4Last Post: January 19th, 2010, 06:42 PM -
Olympus digital voice recorder - software
By JuC in forum Multimedia and AudioReplies: 5Last Post: March 19th, 2009, 12:33 PM
Hmmm. Not so clear he pulled a knife after all:
The FBI has killed another person...
