February 21st, 2011, 08:37 PM #1Junior Member
- Feb 2011
- 2
Laptop outputting DVI signal instead of HDMI (no audio)
I recently got a new HDTV and wanted to hook it up to my laptop (Gateway NV53, W7). The video works fine, but there is no sound. I'm [now] aware that this is a very common problem, but after a day of trolling the internet for solutions I realized that my situation is unique.
The 'HD Audio Device" in 'Playback Devices' always says it's not plugged in. Installing the Realtek HDMI audio drivers changes nothing. I've updated to the latest CCC, audio and BIOS drivers.
I'm using a 1.3V HDMI cable and my TV says:
"1360x768 60Hz DVI"
It isn't the cable, as I've gotten the same results with another one that works fine for the devices it's usually connecting. And it's not the TV, since the same thing happens when I connect my laptop to another HDTV.
I really hope there is some way I can make my laptop output the correct signals, but I haven't a clue how, since there are no [seemingly] relevant settings in the BIOS, CCC, or Control Panel.
Help please !Last edited by pavichokche; February 21st, 2011 at 08:39 PM.
February 21st, 2011, 10:55 PM #2
Disable DTS or any surround sounds options. My guess is your TV will only respond to PCM 2.0 (stereo).
Good job, friend-of-friends!
February 22nd, 2011, 01:35 AM #3
Most laptops will not send the audio over the HDMI cable. With both of my laptops and the one desktop that had an HDMI hookup, I hooked up the headphone cable from the rig into the audio in. You may need to look in your TV manual to find the correct input to go with the HDMI
February 22nd, 2011, 12:55 PM #4Junior Member
- Feb 2011
- 2
Thanks for the quick replies
If you could please elaborate on that. I don't know where or what DTS is.
This is what my playback devices window looks like (disabling the SPDIF Interface doesn't change anything (the few times I've tried).
I understand, but this laptop in particular is supposed to be able to. I've also read online of people who have used it with HDMI and had audio. As for my TV, it's very simplistic (not too too many settings), and according to the manual it just receives what comes in. It says that you can also connect a DVI-HDMI cable in any of the HDMI slots. That is what it is indicating, in fact, that it's receiving a DVI signal (because of the lack of audio perhaps). The issue is [no doubt] from my computer.Last edited by pavichokche; February 22nd, 2011 at 12:58 PM.
June 25th, 2012, 10:47 PM #5Junior Member
- Jun 2012
- 1
Have you found a fix for this.????
same problem here.. a little help will be appreciated.. thx..
Audio and DVI-to-HDMI adapter W/O Grafics Adapter Built-in-Audio chip?
By MegalosSkylaki in forum Graphics Cards and DisplaysReplies: 1Last Post: July 21st, 2010, 02:58 PM -
DVI(PC) to HDMI(TV)
By ry94080 in forum Technical SupportReplies: 0Last Post: May 18th, 2009, 11:14 AM -
dvi to hdmi or dvi to vga? w/c is better?
By jprovido in forum Graphics Cards and DisplaysReplies: 1Last Post: April 15th, 2009, 05:25 PM -
Laptop DVI to LCD TV HDMI - Resolution Stuck at 1280 x 720
By DGalt in forum Graphics Cards and DisplaysReplies: 0Last Post: January 13th, 2009, 02:10 PM -
DVI to HDMI
By cyclist110 in forum Graphics Cards and DisplaysReplies: 7Last Post: May 21st, 2007, 05:37 PM
Move the Users Directory in Windows 7
Full SSD Set files.
