Thread: Xfi Sound Card issue
June 4th, 2011, 02:43 AM #1Junior Member
- Jun 2011
- 2
X-Fi Sound Card issue
Hello, I just reformatted my computer due to some problems. After doing windows updates for an hour or so, i started to get my sound-video all up the date. I updated the X-Fi drivers used the Creative Auto Update program and everything is updated but i cant get sound from the card or even the front side panel after uninstalling drivers and reinstalling. The card is X-Fi Fatality Titanium series.
Here is the DxDiag info:
System Information
Time of this report: 6/4/2011, 06:05:23
Machine name: JON-C09560FC367
Operating System: Windows XP Professional (5.1, Build 2600) Service Pack 3 (2600.xpsp_sp3_gdr.101209-1647)
Language: English (Regional Setting: English)
System Manufacturer: System manufacturer
System Model: System Product Name
BIOS: Phoenix - AwardBIOS v6.00PG
Processor: Intel(R) Core(TM)2 Duo CPU E8400 @ 3.00GHz (2 CPUs)
Memory: 2046MB RAM
Page File: 864MB used, 3074MB available
Windows Dir: C:\WINDOWS
DirectX Version: DirectX 9.0c (4.09.0000.0904)
DX Setup Parameters: Not found
DxDiag Version: 5.03.2600.5512 32bit Unicode
DxDiag Notes
DirectX Files Tab: No problems found.
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Music Tab: No problems found.
Input Tab: No problems found.
Network Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (n/a)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (n/a)
DirectMusic: 0/5 (n/a)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: NVIDIA GeForce 9800 GT
Manufacturer: NVIDIA
Chip type: GeForce 9800 GT
DAC type: Integrated RAMDAC
Device Key: Enum\PCI\VEN_10DE&DEV_0605&SUBSYS_C9733842&REV_A2
Display Memory: 512.0 MB
Current Mode: 1680 x 1050 (32 bit) (60Hz)
Monitor: Plug and Play Monitor
Monitor Max Res: 1600,1200
Driver Name: nv4_disp.dll
Driver Version: 6.14.0012.7533 (English)
DDI Version: 9 (or higher)
Driver Attributes: Final Retail
Driver Date/Size: 5/25/2011 02:09:20, 4198272 bytes
WHQL Logo'd: Yes
WHQL Date Stamp: n/a
VDD: n/a
Mini VDD: nv4_mini.sys
Mini VDD Date: 5/25/2011 02:09:20, 12753664 bytes
Device Identifier: {D7B71E3E-4545-11CF-9F46-7FE903C2CB35}
Vendor ID: 0x10DE
Device ID: 0x0605
SubSys ID: 0xC9733842
Revision ID: 0x00A2
Revision ID: 0x00A2
Video Accel: ModeMPEG2_C ModeMPEG2_D
Deinterlace Caps: {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
Registry: OK
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
DDraw Test Result: Not run
D3D7 Test Result: Not run
D3D8 Test Result: Not run
D3D9 Test Result: Not run
Sound Devices
Description: SB X-Fi Audio [0001]
Default Sound Playback: Yes
Default Voice Playback: Yes
Hardware ID: PCI\VEN_1102&DEV_000B&SUBSYS_00431102&REV_03
Manufacturer ID: 1
Product ID: 100
Type: WDM
Driver Name: ctaud2k.sys
Driver Version: 6.00.0001.1348 (English)
WHQL Logo'd: Yes
Date and Size: 7/7/2010 22:14:20, 537048 bytes
Other Files:
Driver Provider: Creative
HW Accel Level: Full
Cap Flags: 0xF5F
Min/Max Sample Rate: 1, 192000
Static/Strm HW Mix Bufs: 128, 127
Static/Strm HW 3D Bufs: 128, 127
HW Memory: 0
Voice Management: Yes
EAX(tm) 2.0 Listen/Src: Yes, Yes
I3DL2(tm) Listen/Src: No, No
Sensaura(tm) ZoomFX(tm): No
Registry: OK
Sound Test Result: Not run
Sound Capture Devices
Default Sound Capture: Yes
Default Voice Capture: Yes
Cap Flags: 0x41
Format Flags: 0xFFF
DirectMusic
DLS Path: C:\WINDOWS\SYSTEM32\drivers\GM.DLS
DLS Version: 1.00.0016.0002
Acceleration: n/a
Ports: Microsoft Synthesizer, Software (Not Kernel Mode), Output, DLS, Internal, Default Port
SB X-Fi Audio [0001], Software (Kernel Mode), Output, DLS, Internal
Microsoft MIDI Mapper [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
SB X-Fi Synth B [0001] [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
SB X-Fi Synth A [0001] [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
Microsoft GS Wavetable SW Synth [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
Registry: OK
DirectInput Devices
Device Name: Mouse
Attached: 1
Controller ID: n/a
Vendor/Product ID: n/a
FF Driver: n/a
Device Name: Keyboard
Attached: 1
Controller ID: n/a
FF Driver: n/a
Device Name: USB Receiver
Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0x046D, 0xC51A
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0x046D, 0xC52B
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Poll w/ Interrupt: No
Registry: OK
USB Devices
+ USB Root Hub
| Vendor/Product ID: 0x10DE, 0x026D
| Matching Device ID: usb\root_hub
| Service: usbhub
| Driver: usbhub.sys, 4/13/2008 14:45:37, 59520 bytes
| Driver: usbd.sys, 8/10/2004 07:00:00, 4736 bytes
+-+ USB Human Interface Device
| | Vendor/Product ID: 0x046D, 0xC312
| | Matching Device ID: usb\class_03&subclass_01
| | Service: HidUsb
| | Driver: hidusb.sys, 4/13/2008 14:45:27, 10368 bytes
| | Driver: hidclass.sys, 4/13/2008 14:45:26, 36864 bytes
| | Driver: hidparse.sys, 4/13/2008 14:45:22, 24960 bytes
| | Driver: hid.dll, 4/13/2008 20:11:54, 20992 bytes
| +-+ HID Keyboard Device
| | | Matching Device ID: hid_device_system_keyboard
| | | Service: kbdhid
| | | Driver: kbdhid.sys, 4/13/2008 14:39:48, 14592 bytes
| | | Driver: kbdclass.sys, 4/13/2008 14:39:47, 24576 bytes
Gameport Devices
PS/2 Devices
| Service: kbdhid
+ Terminal Server Keyboard Driver
| Matching Device ID: root\rdp_kbd
| Upper Filters: kbdclass
| Service: TermDD
| Driver: termdd.sys, 4/13/2008 20:13:20, 40840 bytes
+ HID-compliant mouse
| Matching Device ID: hid_device_system_mouse
| Service: mouhid
| Driver: mouclass.sys, 4/13/2008 14:39:47, 23040 bytes
| Driver: mouhid.sys, 8/10/2004 07:00:00, 12160 bytes
| Service: mouhid
+ Terminal Server Mouse Driver
| Matching Device ID: root\rdp_mou
| Upper Filters: mouclass
| Service: TermDD
DirectPlay Service Providers
DirectPlay8 Modem Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.5512)
DirectPlay8 Serial Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.5512)
DirectPlay8 IPX Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.5512)
DirectPlay8 TCP/IP Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.5512)
Internet TCP/IP Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.2600.5512)
IPX Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.2600.5512)
Modem Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.2600.5512)
Serial Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.2600.5512)
DirectPlay Voice Wizard Tests: Full Duplex: Not run, Half Duplex: Not run, Mic: Not run
DirectPlay Test Result: Not run
Registry: OK
DirectPlay Adapters
DirectPlay8 Serial Service Provider: COM1
DirectPlay8 TCP/IP Service Provider: Local Area Connection 2 - IPv4 -
DirectPlay Voice Codecs
Voxware VR12 1.4kbit/s
Voxware SC06 6.4kbit/s
Voxware SC03 3.2kbit/s
MS-PCM 64 kbit/s
MS-ADPCM 32.8 kbit/s
Microsoft GSM 6.10 13 kbit/s
TrueSpeech(TM) 8.6 kbit/s
DirectPlay Lobbyable Apps
Disk & DVD/CD-ROM Drives
Drive: C:
Free Space: 211.2 GB
Total Space: 238.5 GB
File System: NTFS
Model: Hitachi HDP725025GLA380
Drive: D:
Model: Optiarc DVD RW AD-7220A
Driver: c:\windows\system32\drivers\cdrom.sys, 5.01.2600.5512 (English), 4/13/2008 14:40:46, 62976 bytes
Audio Renderers:
SB X-Fi Audio [0001],0x00200000,1,0,quartz.dll,6.05.2600.5933
Default DirectSound Device,0x00800000,1,0,quartz.dll,6.05.2600.5933
Default WaveOut Device,0x00200000,1,0,quartz.dll,6.05.2600.5933
DirectSound: SB X-Fi Audio [0001],0x00200000,1,0,quartz.dll,6.05.2600.5933
June 4th, 2011, 08:10 AM #2
Hi Aesop845,
Welcome to TechIMO.
Everything is looking good. Did you plug any speakers into your sound card jack? Are you sure you're using the right jack?
June 4th, 2011, 05:50 PM #3Junior Member
- Jun 2011
- 2
Yes i plugged in speakers and diff headset into the sound card and the onboard front panel plug. I've done all the obvious and even a retard can find problems so please respond with something substantial.
June 6th, 2011, 10:41 PM #4
Sound card issue
By silverhead in forum MotherboardsReplies: 10Last Post: June 16th, 2010, 02:24 PM -
driver/sound card issue
By Losin sux in forum Technical SupportReplies: 5Last Post: November 15th, 2005, 11:59 AM -
A weird issue with the sound card
By bloodybunny in forum Multimedia and AudioReplies: 2Last Post: August 5th, 2005, 04:45 AM -
sound card issue
By sevenal in forum Technical SupportReplies: 13Last Post: November 30th, 2003, 02:49 PM -
Does this sound like a video Card issue?
By Steelysteel in forum Graphics Cards and DisplaysReplies: 0Last Post: July 19th, 2002, 11:14 PM
Strange? I get around 30-45 fps in WoT. Now when I installed GTA 4 same fps but now it drops alot when i look at players tanks, didn't use to do it as much. Fps before GTA 4 was installed was 20fps...
World of Tanks fps drop after...
