Results 1 to 8 of 8
    I got this #43 fan's Avatar
    Mar 2005
    Midwest
    5,560
    Sound driver issue
    Hey all,
    I have Windows 7 installed on my Lenovo Y410. It has a Realtek High Definition Audio "card" installed. So, since Windows Vista's sound worked perfectly, I decided to upgrade to Windows 7 (installed alongside Windows Vista and Fedora 15; Vista has a program which I lost the license key for).
    After the upgrade, the sound no longer works. I have tried the driver that was included in Windows and on Lenovo's website. I also tried the generic Realtek one, but that had many compatibility screens come, which I found suspicious and am wondering if that is normal?
    Does anyone have a suggestion? If so, thanks.
    South Jersey
    11,368
    Hi #43 Fan,
    What do you see in device manager? Unknown device, driver not installed, or what? Tried deleting the device and rebooting?
    One trick that works well with Win 7 is when you're prompted for the location of the driver, click the Windows Update button. Then it will go out to the MS site and can locate drivers for legacy devices.
    Mar 2005
    Midwest
    5,560
    Quote Originally Posted by osprey4 View Post
    Hi #43 Fan,
    The driver is installed just fine; it detects as High Definition Audio device. No sound is coming from the speakers, even though the audio is turned up. I have tried different ports to no avail. External speakers connected through the headphone jack also produced no sound.
    Any ideas?
    South Jersey
    11,368
    I would guess there is some other program controlling the audio output, or the default output device is set incorrectly. I had a similar problem on my Dell and it turned out to be an add-on program for advanced sound options.
    Mar 2005
    Midwest
    5,560
    I tried a different default sound output and no luck. Also, to my knowledge there is no add-on controlling the sound.
    Mar 2005
    Midwest
    5,560
    Additionally, after the computer went into standby the sound now works but sounds rather muted and dull. Definite driver issue somewhere.
    Dec 2008
    East Chamunga
    2,362
    Are you certain the speakers are good?
    Mar 2005
    Midwest
    5,560
    Quote Originally Posted by bigBonehead View Post
    The speakers are good.
    After sleep, apparently I have to switch the default output from the one high definition audio device to the other, which makes the speakers sound clear again.
    I am just wondering why the computer needs to go to sleep then be woken up to engage the speakers.
  1. driver issue
    By Vietster1 in forum General Tech Discussion
    Last Post: September 26th, 2009, 07:16 PM
  2. driver/sound card issue
    By Losin sux in forum Technical Support
    Last Post: November 15th, 2005, 11:59 AM
  3. Replies: 2
    Last Post: July 14th, 2005, 01:50 PM
  4. MAFIA sound issue, voices sound like chipmunks
    By venger417 in forum General Gaming Discussion
    Last Post: April 4th, 2004, 05:57 AM
  5. driver issue
    By mArtOOf in forum Graphics Cards and Displays
    Last Post: January 9th, 2004, 11:40 AM
