Results 1 to 14 of 14
    Jul 2011
    11
    Problem With Creative Sound Card VX 5.1 and
    Hello EveryBody
    Im Going To Tell You My Story ...
    I Buy a Speakes Call : Creative SBS A520 5.1
    And Of Course You Will Buy Sound Card ,,I Choose : *Creative Sound Card VX 5.1*
    it's So Nice ,because i Have the Same Company
    NOTE: My MotherBoard is ECS Geforce 6100-m2
    I Have Many Problems , don't Get Out
    First : My problem is that I can distribute Sound to 5 Speakers
    Second : Problems in activating the EAX ???
    Their : How Can Make it 3D Sound For 3D Sounds
    And Thanks
    Dec 2008
    East Chamunga
    2,362
    W3lcome to the forum...
    Have you tried updating the driver for the sound card?
    Here is a link to the driver
    Jul 2011
    11
    Quote Originally Posted by bigBonehead View Post
    Thanks For Answer
    I Install The Driver From the cd driver
    BUT IM Going to download the Driver from the internet
    Jul 2011
    11
    i install the Driver But Nothing Change :S
    When i run the setup ..
    i have msgbox Show Tell me 'setup unable to detect a supported product on your system please ensure that your product is properly installed before running this setup program '
    what the problem ??????
    Millwright stroyal's Avatar
    Dec 2002
    New Hampshire
    8,189
    Do you get the same message with the disk that came with the card????
    Try this;
    Uninstall the sound card, and all its associated components, in "device manager".
    Shut down the computer, and remove the card.
    Restart, and go into the BIOS, and disable, the on-board sound.
    Restart/ shutdown, and install the sound card, and the drivers.
    You may want to bypass the windows "detect new hardware/install", on start up, and use the program on the disk to install the drivers, and programs after windows starts.
    Last most cards have a control panel, that you set what plug dose what, as well as a program that will set this up, and test it.
    Hard Sayin Not Knowin
    Jul 2011
    11
    nothing Happened
    Dec 2002
    New Hampshire
    8,189
    No.
    Don't post your E-mail, unless you like spam.
    Others may know more than I do, and posts here will get more results.
    Did windows find the card, when you reinstalled it?
    Again, do you get the same message, with both the down loaded version, and the CD version, of the drivers?
    Jul 2011
    11
    No.
    Yep
    With the CD no problem show up
    With the download Show Up the seem Problem :S
    Sorry , im going to Delete my email
    Yes works well BUT this is that it will get out of the rear speakers and center
    When I was trying to test sound
    Just Two Speakers Work The Front Speakers
    and here a Photo For The Driver
    The Front Speakers Work Fine
    But THe rear and the center don't work
    Jul 2011
    11
    What The Problem :S :S :S :S :S :S
    USA
    18,389
    First of all, WHAT OPERATING SYSTEM are you running? Windows XP or Windows Vista Or 7?
    The driver link BigBoneHead linked to above are for Windows 7 & Windows Vista, if your running XP, you will need specific XP drivers.
    Jul 2011
    11
    it's Windows 7 32bit
    can you help me
    Jul 2011
    11
    i have windows 7
    USA
    18,389
    ok, then you have the right drivers.
    As to helping, probably not much, I don't use Creative Products, I stopped using them with the Audigy 4 Sound card I had on my Windows XP machine, 4 years ago, have been using my HT Omega Striker 7.1 Sound card since.
    I got sick of Creatives Crappy driver support, and other Infamous Crackling and popping and general sound quality issues and problems they always faced. Creative does nothing to fix them, other than release another "revised" Crappy product expecting consumers to shell out more money for a replacement, basically milking users for their money. rather than actually FIX the problems.
    at least on their series of sound cards in the $75 and on up range.
    Anyways, the settings and controls for sound cards differ from product to product, I know how to set up MY sound card, but as to yours, not sure.
    but as was said, you should be able to set it up via the sound cards configuration control panel.
    Looking at this video: Unboxing Of Creative SBS A520 5.1 Surround speaker system video on CastTV Video Search
    Seems you need to have 3 audio connectors plugged into your sound card.
    Which means you'll need to configure the sound card to convert some of the output connectors to plug in the audio connectors from the speakers.
    Unfortunately I can't help with that, I know there is some configuring that needs to be done on the sound card itself via the software to allow audio out from the respective jacks to the appropriate speaker connections, for front channels, rear channels and subwoofer. But My Sound card, I use a Single Coaxial Digitial SPDIF output to my 500W 5.1 Home Theater Receiver for my sound system, so I only have a single Output connector to connect to my card.
    I've been doing this now for 5 or 6 years since my first 5.1 Home Theater I had (Some generic 100-150W unit), either using Coaxial Digital out, or Optical TOSLINK digital out put.
    And even before that I never used a Speaker setup that required more than one connection, usually mine had a 3.5mm SPDIF output connector, or I used a 2.0 or 2.1 Setup with a regular single analog connector.
    This is my current Card: HT Omega - Striker7.1
    So as you can see its a whole different beast altogether. The card itself is at least 3 to 4 years old, so most cards in its price range or higher are going to be better as well, the only card higher than it that existed before it or about the same time is the X-fi, though that's the original X-fi, not the newer variants.
    My sound card also has a way of configuring the input connectors and various outputs to use a set of speakers like your Creative speakers, but where its located in my cards setup menu's, I'm not sure, I remember stumbling across them once or twice over the years setting up the cards output and what not, but they'd be located differently in the software than your creative sound cards software anyways, and would be of little help.
    Never mind, I just found my settings, there's a separate program for mine that allows me to setup my Audio output (number of channels, DSP mode, Output mode which allows me to change from Analog to Digital and number of speakers as well as the connectors to use on the card), if memory serves me right my Audigy 4 on Windows XP has a similar setup, different layout, etc, but had similar options to enable for audio output on it as well.
    Dec 2008
    East Chamunga
    2,362
    I'm a little surprised that driver didn't work.Download and run this: Speccy - System Information - Free Download under the audio tab tell us what it shows...
What is 10 and 5 added together?
  1. Creative Audigy 4 - what sound card do you use?
    By rastorize in forum Multimedia and Audio
    Last Post: March 4th, 2005, 09:13 PM
  2. If you have a Creative sound card, look here
    By ShawnD1 in forum General Tech Discussion
    Last Post: June 11th, 2004, 08:13 PM
  3. Replies: 4
    Last Post: September 3rd, 2003, 08:13 AM
  4. urgent: driver for creative vibra 16X pnp sound card
    By Dax_Brandy in forum Technical Support
    Last Post: December 2nd, 2001, 08:53 AM
