September 26th, 2011, 07:39 PM #1Junior Member
- Sep 2011
- 5
Connecting laptop to stereo problem
Hi,
In the past I've connected my PC to my stereo with no problems, in order to listen to mp3 through my stereo speakers. However, I just tried to do the same with my laptop (using a 3.5mm to dual RCA red and white jack cable) and the sound is almost inaudible. Even when I have sound on my laptop and media player on full, the sound coming out of the stereo speakers is very quiet, with a bit of white noise/ speaker hiss, at a volume where on the radio it would be very loud. Please can anyone help or make any suggestions, it's driving me mad.
John
September 26th, 2011, 07:48 PM #2
Hi John,
Welcome to TechIMO.
Can you tell me the make/model of the laptop, and exactly which output jack you are using? Are you sure the output jack is enabled in the laptop?
September 26th, 2011, 08:02 PM #3Junior Member
- Sep 2011
- 5
Hi, and thanks. The laptop is an old Dell Latitude D610 (bombproof, it's outlived its successor).
As for the output jack, I'm using the headphone jack, which was working with a set of small laptop speakers, and works with headphones.
September 27th, 2011, 09:58 AM #4Junior Member
- Sep 2011
- 5
Also, not sure if it's relevant, but there is also a big discrepancy between radio and CD playback volume, for example if '10' is a good volume on radio, I'd have to go to '20' on CD playback to get a similar volume. Thanks
September 29th, 2011, 01:59 PM #5
Have you checked the volume control dialog box? There are separate volume settings for CD, wave, SW synth, etc. Have you got all of the sliders turned up there?
September 30th, 2011, 10:22 AM #6Junior Member
- Sep 2011
- 5
Yes, all volume settings are set to the maximum level, but there is still this big discrepancy where I need to turn the volume up so high to listen to media from my laptop (with associated speaker crackle and hum) that if I then switched to radio it would be deafening! Thanks for your help
September 30th, 2011, 07:59 PM #7
Does that happen with headphones as well?
October 1st, 2011, 04:14 PM #8Junior Member
- Sep 2011
- 5
I'm not sure what you mean... because if I put headphones into the laptop jack I would not be able to compare the difference between the radio volume direct from stereo system and the volume of media played through the laptop. Sorry if I'm being dumb and having a logic fail!
john
connecting computer's audio to stereo receiver
By rhodeye in forum Technical SupportReplies: 2Last Post: April 20th, 2010, 08:18 PM -
stereo mix in asus a9rp laptop
By simo27 in forum Multimedia and AudioReplies: 3Last Post: March 26th, 2008, 09:37 AM -
Problem connecting s-video to tv from ibm A22m laptop.
By dabooj in forum Mobile ComputingReplies: 0Last Post: September 30th, 2004, 10:29 AM -
Laptop To Stereo
By yeeboo in forum Multimedia and AudioReplies: 1Last Post: September 25th, 2003, 02:54 PM -
Connecting to Stereo sys..
By Cruez in forum Multimedia and AudioReplies: 19Last Post: December 20th, 2001, 06:52 PM
After finale of some awesome shows some other exciting shows take place in the Thursday night list have a look. Gigolos Season 4 Episode 6 Rookie Blue Season 4 Episode 1 Save Me Episode 1...
Naruto Shippuden Episode 314 Enjoy
