Results 1 to 9 of 9
    Oct 2011
    13
    Sound Card Upgrade?
    I'm a bit of an audiophile and was wondering if I'd need a better sound card for some HD gaming sound. The mobo I'm getting is the Gigabyte GA-Z68P-DS3 ATX LGA1155. Is it worth buying a sound card or does this have decent enough sound?
    Millwright stroyal's Avatar
    Dec 2002
    New Hampshire
    8,059
    The on-board on mother boards is very good.
    If you are going to get a sound card, you will want to get high end speakers, or it would be a waste.
    Sound cards, usually are not necessary, unless sound, is going to be a big part of the computer.
    Hard Sayin Not Knowin
    Jan 2003
    Outside the box
    8,489
    4
    Just like JP said in your other post its really not needed. You'd be much better off spending the extra cash on a better cpu/gpu (whatever) than you would a dedicated sound card
    Oct 2011
    13
    Alright. I was leaning away from it anyway but I just wanted to get some second opinions. Thanks guys.
    Feb 2007
    Springfield
    13,484
    5
    IMO, there is no point in getting a sound card unless you have something that can actually produce high quality sound. A nice set of speakers or even cans, you WILL be able to tell the difference.
    If you don't have a good set of speakers or headphones, then there is no point spending the money on a sound card.
    FAQ's ~ Team Stats
    My PC
    Dec 2008
    East Chamunga
    2,362
    In my experience, there is a huge difference between a dedicated card made for audio production, such as with a DAW, and the average onboard/gaming add ins. The difference will only be heard on a set of studio nearfield monitors, or a set of cans designed for such work. The average set of consumer speakers are colored to tweak certain frequencies, and the headsets most gamers use are absolutely useless for production work. When you consider the fact that some Creative SB cards go for the same money as something like this, IMO there is no reason the but the SB...
    Feb 2007
    Springfield
    13,484
    5
    I'll throw out the suggestion for Asus sound cards also. The Essence is an amazing sound card, but can be pricey. Also the Creative X-FI Titanium is also an amazing card, and those are getting cheaper since Creative brought out the new line of cards.
    I agree with Bonehead on the speakers though. No point in having a sound card unless you have speakers/cans that can reproduce that high quality sound.
    FAQ's ~ Team Stats
    My PC
    Minnesota
    17,361
    Throw in a suggestion too, besides the Asus, HT Omega's Claro series are good cards too, Though if I remember they only have one or two PCIe cards, the rest are all PCI. Asus has several PCIe models of their PCI versions.
    What? SoloCamo's Avatar
    Nov 2004
    Burning in Florida
    15,194
    4
    Well don't know if this matters as much these days, but I was always advised (and witnessed myself) that a dedicated sound card takes some load off the CPU. Back in the day on my older single cores I noticed the difference in the FPS for games by a 2-3 fps on average increase in frames with one (practically nothing, I know, but when you averaging the low 30's it helps ).
    However, in todays multi-core world I doubt the impact is even that great. Regardless, I've still got a SB live 5.1 pci card that I throw in my rig anyways.
  1. need a upgrade for sound card
    By mycomputerdied in forum General Tech Discussion
    Last Post: November 19th, 2005, 03:57 PM
  2. The most cost-effective sound card upgrade...
    By fpantovich in forum Multimedia and Audio
    Last Post: June 21st, 2004, 10:18 PM
  3. Sound Card Upgrade?
    By NicRuf in forum Mobile Computing
    Last Post: March 31st, 2004, 04:21 PM
  4. Sound Card upgrade!
    By Darthgary in forum Multimedia and Audio
    Last Post: July 25th, 2003, 06:14 AM
  5. Would you upgrade your sound card from this?
    By radio1_mike in forum Multimedia and Audio
    Last Post: February 28th, 2002, 11:17 PM
