November 24th, 2011, 08:45 PM #1Member
- Nov 2010
- 38
What is the fastest DVD burner out there?
What is the fastest DVD burner out there? And how fast can it burn an ISO of a 2 hour movie to DVD?
November 24th, 2011, 09:56 PM #2
24x is pretty much the standard for the fastest write speeds offered you typically don't get that but that would be the fastest theoretic speed. I think it generally takes a few mins to actually burn just the straight data but that depends on how many GBs you are talking about.
What takes forever is the actual encoding/decoding if it hasn't been done already. Just burning the straight iso doesn't take long at all.
November 25th, 2011, 01:00 AM #3
Yeah, those write speeds are pretty misleading considering that the "burning" isn't what takes up the most time during the process. Plus buffer size, etc, all play a role in the overall "speed" of the burn (the process of burning large files that is, from start to finish). Also as Richeem said the speed of the burner isn't ever fully met.
The only thing I can add is that you'll want to inquire as to whether or not the drive has good buffer overrun protection. Users typically compensate for this by selecting slower write speeds with whatever program they are using if they experience errors on optimal settings. But you can do the homework before hand and at least select a device with a good track record.
This technology allows the laser to temporary slow down or halt entirely while the memory buffer is filled back up with information and then writes it.
Buffer Overrun Protection Information: Optical disc recording technologies - Wikipedia, the free encyclopedia
Some info on how/why/when it happens: Buffer Underrun and Overrun Scenarios
Lastly I recommend getting a good name in burners. I'll tell you why: sometimes people go for the best deal possible (especially with BD-Rs/BD-RE for some reason). This isn't the way to go and those drives will die a horrible death (depending on the drive). Optical disc readers and writers are very delicate devices so I recommend doing your homework.
“Arguing with anonymous strangers on the Internet is a sucker's game because they almost always turn out to be—or to be indistinguishable from—self-righteous sixteen-year-olds possessing infinite amounts of free time.” ― Cryptonomicon
DVD burner won't burn DVD but burns CDs
By darkertint in forum Technical SupportReplies: 9Last Post: March 17th, 2010, 08:40 PM -
whats the fastest dvd ripper?
By james long in forum General Tech DiscussionReplies: 13Last Post: November 28th, 2009, 02:16 PM -
Slow CD/DVD burner speeds? My blank DVD tests.
By Kevinator in forum Multimedia and AudioReplies: 3Last Post: September 7th, 2006, 08:19 PM -
3 HD's, dvd burner, and cd burner
By Cellardoor in forum Storage RelatedReplies: 4Last Post: June 27th, 2004, 02:09 PM
I had a blood test once. I failed so they kicked me out of the hospital.
