Results 1 to 4 of 4
    Member Gomar's Avatar
    Oct 2007
    NYC
    105
    best MP3 settings
    same 5 songs converted from WAV to MP3 using:
    CBR128kbs - 25.5mb
    Medium - 23.8
    VBR4 - 28.3
    VBR5 - 23.2
    VBR6 - 21.6
    Using VBR9 sound quality was worst as khz was 24 instead of 44; VBR7, khz32, quality improved.
    Thus khz is more important than kbps. Correct?
    VBR6 is acceptable, 44khz, kbps ranged from 80 to 192.
    VBR5 sounded like CBR128 but smaller file size, 1/12 of WAV, is the best choice.
    A)Why is 0 best, 9 worst? Logic 9 is highest, why backwards?
    B)Why allow user to set min&max bit rates if using VBR?
    C)Why is 128k Tape Quality on some MP3 apps, on others CD quality?
    D)Why is setting to below 112kbs and keeping 44khz not allowed?
    E)Is it better to make MP3s from ripped WAVs or from CDs?
    Dec 2008
    East Chamunga
    2,362
    E) technically speaking, there should be no difference if the ripped wav is 'ripped' from a CD, and into a 16bit 44.1Khz file.
    ◄ it is what it is ►
    Oct 2007
    NYC
    105
    huh? I dont get it.
    Dec 2008
    East Chamunga
    2,362
    OK then...
    If you 'rip' a CD (which by default is a wav @16/44.1) and make it a wav file @ 16/44.1, technically there should be no difference. In my experience though, it depends on the app used to rip it. Studio One (pro D.A.W.) has the ability to do this and create an exact copy...
  1. C:\Documents and Settings\user\Local Settings\Temp
    By jutah in forum General Tech Discussion
    Last Post: April 6th, 2008, 03:21 AM
  2. File and transfer Settings Wizard and email settings?
    By celebritymusic in forum General Tech Discussion
    Last Post: July 31st, 2006, 02:27 AM
  3. how do i order mp3 tracks on a sony mp3 player!!
    By wolfmanssister in forum Multimedia and Audio
    Last Post: February 14th, 2003, 08:51 PM
