March 28th, 2012, 12:53 PM #1Junior Member
- Mar 2012
- 1
Need to connect VGA to PC or HDMI to PC
I have a 50 inch Sony Bravia flat screen HDTV. I have CAT5 install to room from the front of the conference room to the table so potential clients can connect their laptops to the TV screen using some sort of transceiver. I currently have a Cat5 to VGA transceiver which doesn't work to well. I purchase this HDMI to CAT5e converter from amazon by SABRENT I don't know if this is the actual device I needed. Does anyone have any suggestions on how to make this work with the current installation (Cat5e installation) I dont mind using the VGA extension if thats the only way available.
March 28th, 2012, 05:57 PM #2
Remote desktop/VNC programs and a wifi connection may be an easy solution.
Virtual Network Computing - Wikipedia, the free encyclopedia
VGA and HDMI Issue with Samsung TV
By eatdirt_13 in forum Graphics Cards and DisplaysReplies: 1Last Post: January 31st, 2012, 12:12 PM -
dual display vga and hdmi
By stevemu in forum Graphics Cards and DisplaysReplies: 1Last Post: September 19th, 2010, 05:08 PM -
HDMI/VGA to RCA tv?
By Jeff22 in forum General Tech DiscussionReplies: 1Last Post: August 7th, 2010, 03:56 PM -
can't use hdtv via hdmi without having vga plugged in as well
By jobenny394 in forum Graphics Cards and DisplaysReplies: 0Last Post: August 29th, 2008, 11:58 PM
Ouch, idle temp is way too high. Should be idle around 30-45c Top temps at load should be 80-85, anything more than 90 and its running hotter than it should. Make sure the case fans are...
Radeon 7870 or GTX 660 - which is...
