Results 1 to 2 of 2
    Apr 2012
    LA,USA
    12
    a plugs on a tv card?
    I have an existing tv card on my computer that is working fine. I want to add my dvd player to the mix, but it has so many connection at the back that Im a bit confused. thanks in advance for help.
    Jan 2003
    Outside the box
    8,489
    4
    Well what output connections are available on your VCR and what input connections does the tv tuner have? Without knowing that it'll be hard for us to give you any advice.
    Do you know the make and model of either?? or even the make and model of the PC?
  1. where do these plugs go?
    By nubcake in forum General Tech Discussion
    Last Post: November 4th, 2005, 12:29 PM
  2. 5.1 plugs
    By CanNiBaL513 in forum Multimedia and Audio
    Last Post: October 10th, 2004, 02:15 AM
  3. focus fk7200 keyboard plugs
    By bsamot in forum Technical Support
    Last Post: June 28th, 2004, 12:10 PM
  4. NF7-S Power plugs
    By Mr. Anderson in forum Motherboards
    Last Post: June 11th, 2004, 06:17 PM
  5. Can monitor plugs be repaired?
    By speedstik in forum Technical Support
    Last Post: August 29th, 2003, 09:41 AM
