Results 1 to 5 of 5
    Apr 2012
    LA,USA
    12
    my audio DVD player can’t work?
    I’ve never learned how and there insint anything in the handbook! What’s the normal way to make the DVD player play through the speakers of my car?
    this is mine: link here
    When I put in a DVD the audio isn't working i think it’s supposed to run through the cars speakers but I’m not sure if it has anything to do. How can I fix the audio or how can i find out What’s wrong? Any help will be appreciated.
    Minnesota
    17,362
    Um, first of all, technically this isn't a PC hardware tech topic...
    2nd, do you get ANY audio through the car speakers? If so, its probably an option or setting in the menu's for the DVD Player, not an issue of Wiring or anything.
    I'd find the manual, or see if there is one online to download and read it.
    Apr 2012
    2
    Unless it is a bad cable it is probably a bad connection.
    Connect the DVD player to Component 1 (using r/g/b cables)
    Connect now r/w audio corresponding to those video cables.
    Switch TV input to Comp 1 - Audio? If yes, you are done.
    If not, using the TV's remote try ALL ports . If you hit audio, then you connected the cables to the wrong TV port. Replace and try again.
    Dec 2008
    East Chamunga
    2,362
    Quote Originally Posted by qwertyui View Post
    since this unit is for the automobile, not home, your suggestions are N/A
    ◄ it is what it is ►
    Apr 2012
    LA,USA
    12
    thanks,I just wish to give a huge thumbs up for the nice answer you have here on this post.
  1. Dvd in media player won't work!
    By ronald1967 in forum Multimedia and Audio
    Last Post: December 11th, 2011, 09:43 PM
  2. dvd player to receiver, audio cables
    By ChuchDaoo in forum Technical Support
    Last Post: December 21st, 2008, 08:49 AM
  3. My burned DVDs dont work on my DVD player
    By raiyanb in forum General Tech Discussion
    Last Post: March 22nd, 2006, 05:56 PM
  4. DVD Player playing Audio DVD's, a question.
    By _Switch_ in forum General Tech Discussion
    Last Post: January 17th, 2006, 03:58 AM
  5. Sony DCR-DVD 92, Mini DVD, How do I play this in Media Player?
    By Epidemic in forum General Tech Discussion
    Last Post: August 2nd, 2005, 02:00 PM
