Results 1 to 9 of 9
    Member Wasted's Avatar
    Aug 2006
    England
    361
    Batch audio editing application
    I'm looking for an app that will remove the first 5 seconds off a couple of hundred mp3's. Can anyone recomend a good one?
    Cheers.
    Windows 7 Professional 64, I7-920 @ 3.8, ASUS P6T Deluxe V2, 6Gb Corsair Dominator @ 1448, 2 x Gainward GTS 460 1Gb, System: 90Gb Corsair Force 3
    Games: 2 x 150Gb Velociraptors in RAID 0
    Jan 2003
    Outside the box
    8,489
    4
    I know audacity allows batch processing but that is meant more for conversion or applying filters. I'm not certain it would do editing nor I'm I aware of anything out there that would allow that type of batch editing.
    Its free- you could try it and see
    Aug 2006
    England
    361
    Cool, i'll try that. Cheers dude.
    Jan 2003
    Outside the box
    8,489
    4
    I looked all over the settings and like I said it allows you to add filters and create a few custom batch scripts but I don't see the option of actually batch editing the file. You can tweak things like change pitch, add bass boost, export to file, level adjust ect but I can't see a way to add anything that would allow editing.
    Sorry if that isn't much help, maybe someone else will have another suggestion.
    Aug 2006
    England
    361
    Ahh bugger. Must be something somewhere that does it.
    Dec 2008
    East Chamunga
    2,362
    I believe Goldwave will do that, but it's not a free app...
    ◄ it is what it is ►
    Aug 2006
    England
    361
    I shall investigate, cheers.
    Aug 2006
    England
    361
    Goldwave does it, and does far more superb bit of kit, cheers for you help dudes.
    Apr 2012
    20
    I am using Goldwave and I am happy with it. One of the best things I did was to reduce the bass with it.
  1. Advice Wanted: Any application for securely saving and editing a document on iphone.
    By hauntedscientist in forum Applications and Operating Systems
    Last Post: October 19th, 2011, 01:17 PM
  2. Editing Audio
    By Undeadlord in forum Technical Support
    Last Post: June 6th, 2007, 05:48 PM
  3. A Not-Overwhelming Gfx Editing Application
    By jetman in forum Graphic Design and Digital Photography
    Last Post: September 18th, 2006, 09:51 PM
  4. Audio editing
    By roosta21 in forum Multimedia and Audio
    Last Post: January 11th, 2005, 09:54 PM
  5. Replies: 3
    Last Post: December 30th, 2003, 02:14 AM
