Results 1 to 5 of 5
    Ultimate Member cksboy15's Avatar
    Nov 2008
    Columbus, Ohio, Unit
    1,427
    5770 HDMI sound quality
    So running HDMI from my computer's video card (saphire amd 5770) to TV that runs composite RCA to my stereo (Sharp HT-DP3000) that only accepts RCA
    What I'm getting for sound quality is pretty much bass only.
    I ran a auxilary cable (3.5mm connections on both ends) from the computer to the TV and that works fine, but I want to be able to use my 5.1 surround sound.
    So the question is. could it be the new HDMI cable, the TV's HDMI connection or the video card's audio just being that bad.
    btw almost went a full year without posting >.> I missed this site kinda
    Verizon FiOS Tier 2 Technical Support
    Minnesota
    17,373
    It might very well have something to do with the Digital to Analog signal conversion. HDMI transmits via Digital, Composite is an Analog signal. Could be something is getting lost at the TV outputting to the RCA plugs.
    But thats just a guess, no idea for certain.
    On my end, I either use a Sound card with Coaxial Digital Out or my current Mobo has a Coaxial Digital Out for Sound to my Home Theater so its always Digital no matter what. I also use a DVI to HDMI Converter cable, and input via HDMI into my monitor.
    Nov 2008
    1,427
    My problem with that is that my stereo only accepts the RCA plugs. though I do agree that might very well be the case.
    I'm thinking it's more the HDMI cord or the video card though cause i can play the xbox (which I'm using a component cable for) and watch the antennae TV (hey I'm a cheap bastard, ok?) with better sound quality than the computer.
    Minnesota
    17,373
    thing is, using the Component Output for Xbox 360, its outputting Analog audio with the video signal as well (though capable of a max of 720p HD Video), so little to no conversion on the TV's end to pass through to Stereo.
    Does your Xbox have an HDMI output at all? if it does, try connecting that to the TV like the PC and see if it results in similar sound issues.
    Nov 2008
    1,427
    I cited the xbox cause I run the component's audio to the TV not the stereo, probably coulda been a bit clearer about that.
    As for an HDMI output, no first gen xbox didn't have hdmi ports just overheating motherboards.
    I'm gonna hit up microcenter today anyway I'll pick up an hdmi cord while I'm there and see if it's the cord.
  1. No HDMI sound on TV
    By coolcise in forum Technical Support
    Last Post: October 15th, 2011, 10:08 AM
  2. Laptop to TV HDMI, NO SOUND
    By DivineSage in forum Technical Support
    Last Post: May 29th, 2011, 09:10 PM
  3. SUDDENLY NO HDMI SOUND
    By Crispbac in forum Technical Support
    Last Post: November 27th, 2010, 01:26 PM
  4. HDMI PC to TV sound issue
    By CTCF in forum Multimedia and Audio
    Last Post: September 8th, 2010, 03:15 AM
  5. PC: DVI to HDMI Sound Problem!
    By Cappy445 in forum Multimedia and Audio
    Last Post: October 10th, 2009, 01:36 AM
