Results 1 to 9 of 9
    eoS
    eoS is offline
    Aug 2012
    5
    Exclamation Sound Driver HELP PLS!!!
    Hello there! i got a problem...i got a sound card name it: Seismic Edge Philips PSC705 5.1 Channel PCI Audio (with DIGITAL OUTPUT) and i cant find a update or a new software for WIN7...please help..i try it on they site...but only lower then xp,2000,me,98, etc...Please help me
    Minnesota
    17,362
    I already asked a mod to delete your first post, as there's no need to make duplicate postings for the same thing, and since this thread is what you should of done in the first place, no need to have a revived dead thread with the same thing asked in it.
    I looked the card up, and sure enough there is no Win7 drivers, from what I have tried to find out it uses some sort of proprietary Phillips sound chip, Something Avenger sound chip or something like that.
    If this is just a rebadged Realtek or C-Media sound chip (I didn't dig around that much to find out), you might be able to get Windows 7 drivers for it, or at the least Windows Vista drivers that might work.
    Otherwise, since its a/was a fairly cheap sound card, might have to just buy a new one, that would fill in, in its place.
    cconsidering the card dates back to 8-10 years ago, it won't be that hard to find a card that is superior to it for cheap these days.
    eoS
    eoS is offline
    Aug 2012
    5
    Thx for and sry...only one question...tell me please what sound card is good for a logitech z5500...mby you know smth about this..not very expensive but not so...thx a lot for help!! i need for music..minimal/club/tech/electro/dance/MOVIES!!
    Minnesota
    17,362
    Myself I'm not 100% sure, but I would think the lower end Asus Cards would be more than enough.
    Right now I mainly use my motherboards Onboard Audio, but for years I have used a higher end HT Omega Sound card, Striker 7.1, that is around the $75-80 range, but wanting to get one of HT Omega's higher end $150-200 range cards.
    Newegg.com - Computer Hardware, Soundcards, Speakers & Headsets, Sound Cards, ASUS
    one of their cheaper cards should be adequate, if not at least the same or superior to the old Phillips card.
    when you say Digital Out, do you have a SPDIF 3.5mm Output? Coaxial Digital Out, or Toslink Digital Out?
    I don't remember which output connector the Z5500's use, I'm assuming its a 3.5mm SPDIF connector.
    Otherwise, Diamond, which swallowed up Phillips cards I believe, or maybe it was the other way around, I forget, but they have a cheap card that would be as good:
    Newegg.com - DIAMOND XtremeSound XS71 7.1 Channels 16-bit 96KHz PCI Interface Sound Card
    otherwise for music, these would be much better IMO: Newegg.com - Computer Hardware, Soundcards, Speakers & Headsets, Sound Cards, HT Omega
    but those aren't exactly cheap, and that Striker 7.1 is at least 5 years old now, and still commanding a high price.
    what ever you do, don't go for a Creative card.
    eoS
    eoS is offline
    Aug 2012
    5
    oke so you tell me coz asus card are ok? i don`t rly know this category coaxial etc is normal jack...black green and orange Digital
    Minnesota
    17,362
    is the digital a standard Headphone jack? (3.5mm jack)
    Is it a Coaxial (Looks like a standard RCA style Composite connector)
    Or Toslink, which is Fiber Optic connection, square-ish looking connector?
    Nevermind, I looked up the card again, and its the green 3.5mm jack (SPDIF).
    then one of those cheaper Asus cards should be fine.
    Minnesota
    17,362
    just make sure its a PCI slot version, as some are PCI Express x1 slot as well.
    Unless of course your motherboard has a PCI Express x1 slot available, then you could easily use one of those also.
    eoS
    eoS is offline
    Aug 2012
    5
    thx a lot man for these a lot of help and time!!!
    Dec 2010
    Lebanon
    310
    There are two ways to install this card on win 7 :
    1 - open windows update and in the category " change settings " , put a check on " Give me recommended updates the same way i receive important updates " . then run the check for updates and let windows install all of them ..This is how i usually install (successfully) the difficult to find Audio drivers like the "Conexant Ac Link Audio"..
    2 - Try to install the XP driver by letting the card search for the best driver and directing it to the contained folder ..
    Good luck .
  1. NEED SOUND DRIVER!
    By Relleke in forum Technical Support
    Last Post: December 30th, 2009, 12:11 AM
  2. Sound Driver
    By Vistary in forum Technical Support
    Last Post: May 30th, 2009, 12:46 PM
  3. pls help me...driver for inspiron 4150 dell
    By farriz_malaysia in forum Networking and Internet
    Last Post: February 20th, 2008, 04:46 PM
  4. sound driver
    By Germain in forum Technical Support
    Last Post: February 13th, 2008, 07:29 PM
  5. Sound driver
    Last Post: September 17th, 2005, 06:56 PM
