Join TechIMO for Free!
Topic: I have some track which are in mp3 and rm format. Unfortunatly, i cannot covert them and write them on to a cdr as one mp3 file is very big. Does anyone know who to cut the mp3 file so I dont lose andy sound quality?? ...
Thread Tools
Currently Active Users: 2483
Discussions: 186,270, Posts: 2,223,082, Members: 229,834
Old September 25th, 2002, 05:12 AM   Digg it!   #1 (permalink)
mp3 too big to copy on to cd
Thanks in advance
Hamza is offline   Reply With Quote
Old September 25th, 2002, 05:21 AM     #2 (permalink)
Retired mostly.
If you're planning to writing normal audio cd (I can't imagine a mp3 file larger than 700MB), the burning program automatically converts the mp3 back to wav (you've lost quality at the initial compression which reflects on decompressing it back to wav).
Wav files are easily modified with any sound manipulation tool, like soundforge, cooledit etc. Thus, you could convert it by hand to wav, cut it in two, and then add the wavs to the cd.
-M
Old September 25th, 2002, 06:36 AM     #3 (permalink)
Thanks I will try that.
it's just that the mp3 is of a lecture which is in excess of 85 mins long and hence..... even though the actual mp is no larger than 20 megs big
Old September 25th, 2002, 06:52 AM     #4 (permalink)
Send a message via ICQ to Chunky
Have you tried using 99 minute media?
(though 99 minutes is the best case - it depends on the CDR drive you're using)
http://www.medeainternational.com/info/90min.htm
These are the disks I use.
Hope this helps,
Chunks.
Catch ya on the flip side!
http://www.chrisnorman.btinternet.co.uk/evil.gif
Chunky is offline   Reply With Quote
Old September 25th, 2002, 07:01 AM     #5 (permalink)
Retired mostly.
Excellent point. Most burners will overburn ~85mins. My plextor does 94min but it's pretty much brand specific. You can find more info on it here -> http://www.cdrinfo.com/Sections/Hardware/All.asp
Or, you can use tools provided by ahead to check out yourself the capabilities of your drive.
-M
Old September 25th, 2002, 08:35 AM     #6 (permalink)
PCLinuxOS MiniMe 2008
dunbar's Avatar
Send a message via ICQ to dunbar
Alternate idea
Burners which can overburn are not always trustworthy when they are in overburn mode. Also, what about older CDRW hardware and software - maybe they can't get beyond 650?
I'm no guru, but maybe they could downsample a tiny bit?
--Tell the Linux developers to write accurate and timely docs 'cuz they read their own code the best. Tell them to put them in the system, too.
dunbar is offline   Reply With Quote
Old September 25th, 2002, 08:48 AM     #7 (permalink)
Retired mostly.
Even my old hp7200 drive would burn 700mb discs - granted the firmware update.
Of course that's a bit more professional solution, so cutting it in two might be easier.
-M
Old September 25th, 2002, 10:11 AM     #8 (permalink)
Banti's Avatar
Send a message via Yahoo to Banti
Even if he downsamples that will not reduce the time of the clip. The time will remain 85 minutes.
Banti
Banti is offline   Reply With Quote
Old September 25th, 2002, 10:30 AM     #9 (permalink)
dunbar's Avatar
Banti
D'oh!
Old September 25th, 2002, 11:03 AM     #10 (permalink)
ᅟᅠ
OuTpaTienT's Avatar
With something like Steinberg's Wavelab you could fairly easily compress the entire thing from 85 minutes down to under 80 minutes which is the size of a 700MB CD. You could also easily correct the pitch back down to normal if it was even necessary.
OIC 0utpatient.com
OuTpaTienT is offline   Reply With Quote
Thread Tools
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
residential adsl design (5)
Is It Just Me? (17002)
FolderChat: Weekend time again! (315)
The F word (under-utilized or horri.. (43)
My Best OC Ever (10)
Folderchat Weekday thread (373)
Motherboard installation (8)
Super folding (20)
no good at fps.... (6)
Welcome new Members. (11)
Boot up issues with an KN1 extr.. (8)
need hp 6000 disks (0)
Advice:Which anti-Virus to buy? (4)
Can't stop apps from starting o.. (4)
Password lost, unable to open c.. (1)
floppy drive/ dvd drive help (1)
Monitor not workin cause of boo.. (1)
9800GTX 512meg (9)
Six 28-Disc Cross Design Black .. (1)
FS: New Benny Hill Megaset DVD .. (1)
