can i copy a copy-protected DVD onto a VCD?+
Currently Active Users: 1956
Discussions: 200,920, Posts: 2,379,084, Members: 246,289
Old February 11th, 2003, 07:30 PM   Digg it!   #1 (permalink)
Banned
ZepplinStones's Avatar
Question
how can i get a copy-protected DVD onto my hard drive or a VCD? Software recomendations?
ZepplinStones is offline   Reply With Quote
Old February 11th, 2003, 07:32 PM     #2 (permalink)
Fact Checker
Gomer's Avatar
illegal and most discussion frowned upon here... I suggest www.google.com
Gomer is offline   Reply With Quote
Old February 11th, 2003, 07:37 PM     #3 (permalink)
MrLuigi's Avatar
www.vcdhelp.com or www.doom9.org
Does this mean you don't want any cookies?
MrLuigi is offline   Reply With Quote
Old February 12th, 2003, 02:45 AM     #4 (permalink)
Retired mostly.
It depends where you live whether it's illegal or not.
All dvd's are copy protected, follow mrluigis links.
-M
Old February 12th, 2003, 02:50 AM     #5 (permalink)
Jeordiewhite's Avatar
Send a message via ICQ to Jeordiewhite Send a message via AIM to Jeordiewhite Send a message via Yahoo to Jeordiewhite
I have used dvd x copy 1.3 to make a copy of a dvd, as for VCD, I use VOB http://www.vob.de/ to do vcd's tho I have only tried one vcd before.
(´¸.·*´¯`*»- ->Jeordiewhite
Jeordiewhite is offline   Reply With Quote
Old October 21st, 2008, 05:22 AM     #6 (permalink)
i'm using Any DVD Cloner (http://www.any-dvd-cloner) to burn copy-protected DVD to DVD discs.
i think you can use another freeware DVDSmith Movie Backup (DVDSmith Movie Backup: DVD Decrypter to copy DVD movie to computer hard disk, and remove all the CSS, RC, RCE, APS, UOPs and Sony ARccOS protections) to copy the protected DVD onto your hard drive first, and then use other free burning software to burn the entire folder to VCD.
fifiward is offline   Reply With Quote
Is It Just Me? (2853)
Obama the Muslim (13)
radeon x850xt platinum & shader 3 (0)
Virus Doctor Popup? (1)
SIS 740 and Widescreen (8)
PSP Go bought in Japan (0)
