Connecting to Stereo sys..
Currently Active Users: 1102
Discussions: 204,523, Posts: 2,419,661, Members: 249,943
Old December 2nd, 2001, 08:30 PM   Digg it!   #1 (permalink)
Cruez's Avatar
Send a message via ICQ to Cruez Send a message via AIM to Cruez
I want to connect my PC's sound card to the stereo in another room... What would be the cheapest way to go and still have good quality. It wont really be permanent ...just for Christmas muci in the other room...
No one dies a virgin, Life screws us all.
Cruez is offline   Reply With Quote
Old December 2nd, 2001, 08:50 PM     #2 (permalink)
bigblue77's Avatar
Send a message via ICQ to bigblue77 Send a message via AIM to bigblue77 Send a message via Yahoo to bigblue77
For mine I just took a old RCA adapter cable from a walkman and used RCA gender changers to connect to a set of long RCA cables. Its probably the cheapest way to go, unless you buy RCA plugs and a roll of speaker cable and make your own RCA cables.
Jer
Thread Killer
bigblue77 is offline   Reply With Quote
Old December 2nd, 2001, 09:45 PM     #3 (permalink)
Cruez's Avatar
Can you buy a splitter to change the small output plug in the sound card into two RCA type connectors???...If so cand you just pick em up at Radio Shack??.
I have some speaker wire left over I could use to make the RCA cables..
Old December 2nd, 2001, 09:55 PM     #4 (permalink)
if your talking about what I think your talking about, then yes!! you mean, like a headphone jack to rca plugs?? yes, there is such thing, many discmans come with them for hooking the discman up to a stereo. and yes, radio shack should have them!
cya!
^hyd^ is offline   Reply With Quote
Old December 2nd, 2001, 10:12 PM     #5 (permalink)
bigblue77's Avatar
Yes you can get them at Radio Shack
http://www.radioshack.com/product.as...5Fid=42%2D2483
Theres a link to the splitter. You can either cut the plugs off and solder speaker wire to it, and put a RCA plug on the end. Or you can get gender changers and make yourself some RCA's with the speaker wire. Good Luck.
Jer
P.S. Thay do have a cheaper and shorter version of this, but on the website it said it is anavailable at this time, but I am pretty sure that pertains only to the website
Old December 2nd, 2001, 11:37 PM     #6 (permalink)
Cruez's Avatar
thx guys....I'll get em tommorrow...
Old December 2nd, 2001, 11:46 PM     #7 (permalink)
The Mad Redhatter
storm2k's Avatar
Send a message via ICQ to storm2k Send a message via AIM to storm2k Send a message via MSN to storm2k Send a message via Yahoo to storm2k
i do that. my stereo is about 1.5 feet from my pc, so i did that route mentioned above and it works beautifully.
i run a splitter from my audio out jack on my soundcard (in order to use both my comp speakers and my stereo) and then picked up a male to male 1/8" to rca cable at a show and hooked that into my stereo. it works beautifully, and i can use my stereo's high quality audio enhancements to make the sound come out nicely.
storm2k is offline   Reply With Quote
Old December 2nd, 2001, 11:55 PM     #8 (permalink)
bigblue77's Avatar
Thats the same thing I do, except I let my stereo do all the fine tuning. Its audio processor is WAAAYYY more advanced than my PC's. I just feed my stereo the "line-out" from my sound card.
Old December 3rd, 2001, 12:10 AM     #9 (permalink)
The Mad Redhatter
storm2k's Avatar
well i have a soundblaster live! card, so it can do quite a bit of audio mixing on its own, which is nice. combine that with winamp's equalizer and i got some nice sounding music.
Old December 3rd, 2001, 12:18 AM     #10 (permalink)
bigblue77's Avatar
I just have a SB 32(remember them lol), but at the time it was better than what i had.
Is It Just Me? (1631)
An Inability to Be Civil (21)
newegg=bad people (31)
USB not recognised..... (16)
First time builder (6)
Recent Problem (15)
Need some suggestions on building a.. (34)
HTML (7)
[ F@H Chat] 03/07/10 New Month New.. (92)
Motherboard the culprit? (7)
Windows XP Pro Error log (9)
Suggestions? (6)
Need some suggestions on building a g.. (34)
Outlook keeping 2 copies of sent mess.. (2)
SSH Tunnel Or OpenVPN? (2)
TV tuner (1)
C# Sql Server 2005 Connection Issue (0)
GOM Player with Google Chrome? (0)
First Time PC Builder (Gaming PC) (1)
[ F@H Chat] 03/07/10 New Month New T.. (92)
HTML (7)
re laptop (1)
pc won't start (1)
Audio skips when I play a cd or dvd o.. (2)
Microsoft removes hardware virtualiza.. (1)
Lexmark Printer Prestige pro805 (1)
Hypercam 2 plays sound too fast (1)
IE8 & WLM crash whenever I try to.. (1)
iPad, who's getting one? (60)
Writing lead-out (8)
About to install a new heatsink and I.. (3)
169 ip address question (4)
Help! Cisco Switch port (interface) f.. (1)
