Wireless speakers for PC?
Currently Active Users: 1527
Discussions: 200,933, Posts: 2,379,170, Members: 246,297
Old July 20th, 2003, 03:22 AM   Digg it!   #1 (permalink)
jerrygarcia's Avatar
Send a message via AIM to jerrygarcia Send a message via Yahoo to jerrygarcia
Is there a way that I could add a couple of wireless speakers into my PC? I use my machine as a big jukebox/MP3 player and want to know if I could somehow link some wireless outdoor speakers to my machine. Wired is kinda out of the question due to vaulted ceilings.
I have a Turtle Beach Santa Cruz sound card and Klipsch 4.1's. I would like to add some indoor/outdoor wireless.
Do I need to hook up with my receiver to do this and how can I connect the two?
jerrygarcia is offline   Reply With Quote
Old July 20th, 2003, 07:44 PM     #2 (permalink)
Have I stumped the great minds of TechIMO?
Old July 20th, 2003, 08:02 PM     #3 (permalink)
ph34r t3h g04t
Whir's Avatar
Well, on a quick search, all the wireless PC speakers I found were small and most likely inadequate for your setup. I've never seen a wireless rig from any of the big names.
The only other problem with wireless is that you'll either have to plug them into the wall, or they'll be battery operated.
Old July 20th, 2003, 10:49 PM     #4 (permalink)
How about being able to connect my pc to my receiver and run some indoor/outdoor wired(I'll have to figure out a way to run wires) speakers and still use my pc as a jukebox?
Old October 3rd, 2003, 12:41 AM     #5 (permalink)
Dragging up this subject again to get some/any ideas.
Thoughts?
Old October 22nd, 2009, 12:27 PM     #6 (permalink)
Why do you just look for your PC. There are wireless speakers that can be used with your stereo systems, mp3 players, CD player, television and obviously, your PC.
Don't go for the PC alone.
digigrace is offline   Reply With Quote
Old November 2nd, 2009, 07:44 PM     #7 (permalink)
RayH's Avatar
Get a pair of Bluetooth speakers.
TheGreatRaymond@sbcglobal.net
Please indicate you are from TechIMO in subject line so you don't get deleted as spam :)
RayH is offline   Reply With Quote
Old November 10th, 2009, 03:04 PM     #8 (permalink)
Yup, pair of Bluetooth speakers is a great choice. But not sure how long it can stream and not sure about how many hours it can withstand.
Old November 19th, 2009, 07:57 AM     #9 (permalink)
There are many wireless speakers for the PC. I had acquired "Sony SRS-RF930RK" Wireless Speaker for my PC and it's awesome. It cost me around $75 . It is cool gadgets that i use currently.
kristinacallis is offline   Reply With Quote
Old November 19th, 2009, 09:40 AM     #10 (permalink)
bigBonehead's Avatar
Hey JG... if you haven't found anything yet... here's some good info: Wireless Speakers Systems: A buying guide to Wireless Home Theater
Wisdom comes with age, but sometimes age comes alone...
bigBonehead is offline   Reply With Quote
Is It Just Me? (2876)
Obama the Muslim (14)
Ideal cheap graph card for PC-Gamin.. (17)
CPU fan stops spinning randomly (0)
Wireless Televisions. (0)
favorit (1)
Regular Build (3)
Fire in DVD (2)
Have you switched yet? (84)
Optical Audio A-B Switch (1)
