converting mp3 to wma
Currently Active Users: 1975
Discussions: 200,936, Posts: 2,379,225, Members: 246,301
Old July 27th, 2003, 02:58 PM   Digg it!   #1 (permalink)
Question
I want to convert mp3 files to wma so I can put more songs onto my Sonicblue Rio 800 mp3 player. I'm using Advanced MP3 Converter version 1.82 and was easily able to convert. The problem is the converted wma files aren't any smaller. What do I need to do to convert mp3 into smaller wma or can I not do what I want to do.
dmayne99 is offline   Reply With Quote
Old July 28th, 2003, 02:44 AM     #2 (permalink)
Retired mostly.
Does that rio even support wma?
You need to alter the bitrate for smaller file sizes.
-M
Old July 28th, 2003, 02:49 AM     #3 (permalink)
Reknup's Avatar
Send a message via AIM to Reknup
Ummmm thats really dumb!
Mp3's are way Smaller then Wave (wma) files
Go MP3....
Wave Files are huge
Sound-You cant tell the difference unless your superman (sonic hearing)
Reknup-DSA* Tribes Leader 2003
Reknup is offline   Reply With Quote
Old July 28th, 2003, 02:55 AM     #4 (permalink)
Mead's Avatar
The problem is you are converting from one lossy format to another, so it cant really compress any more than the mp3 already did. What you need to do is to rip the files to wav then convert the wav files to wma. Whatever you do, dont convert the mp3's to wav then convert the wav files to wma the sound quality will be horrid and not in anyway worth the extra couple kb's you save in space.
Mead is offline   Reply With Quote
Old July 28th, 2003, 03:01 AM     #5 (permalink)
Retired mostly.
wma is not wav.
Yes it can compress them more by adjusting the bitrate.
You can easily test it by converting a raw avi file to 1000kbs avi file, and then re-encoding it to 100kbs avi file. Which one of them is smaller? Try and see.
-M
Old July 28th, 2003, 03:07 AM     #6 (permalink)
nuisance since 1968
OuTpaTienT's Avatar
Go MP3....
Wave Files are huge
wma files are not wave files.
I would also suggest sticking with mp3 just because I really do not like the wma format.
Yes you can tell the difference, and you don't have to be Superman.
OuTpaTienT is offline   Reply With Quote
Old July 28th, 2003, 08:52 AM     #7 (permalink)
Guest
Darthgary's Avatar
Send a message via AIM to Darthgary
There is plenty of MP3 to WMA Proggy's out there, If you have Windows XP, you can get plus XP which has a tool to do that. The results are very good, A file that sounds the same and long as you choose a high bitrate, and is about 2 MB smaller.
Darthgary is offline   Reply With Quote
Old July 28th, 2003, 10:59 AM     #8 (permalink)
Thumbs up
Originally posted by muno
wma is not wav.
-M
Thanks Muno! I was able to adjust the wma bit rate - 160 works pretty good - makes about a 40% reduction in size. Works good quality-wise as long as the MP3's are at least 256mbps. Thanks again!
Old July 28th, 2003, 03:37 PM     #9 (permalink)
The Mad Redhatter
storm2k's Avatar
Send a message via ICQ to storm2k Send a message via AIM to storm2k Send a message via MSN to storm2k Send a message via Yahoo to storm2k
64 kbit wmas actually sound pretty good in comparison to 128 kbit mp3s. you can acutally use windows media player (v7 or greater) or a recent winamp version to do the conversions.
storm2k is offline   Reply With Quote
Old July 28th, 2003, 05:23 PM     #10 (permalink)
nuisance since 1968
OuTpaTienT's Avatar
Well, I think this advice is going to depend on your ears. Personally I like 128bit mp3s and I wouldn't even give 64bit wmas the time of day.
windows 7 problem (6)
Is It Just Me? (2896)
Wireless Televisions. (8)
Obama the Muslim (14)
Modern Warfare 2 freeze (13)
CPU fan stops spinning randomly (3)
wireless user (1)
favorit (1)
Regular Build (3)
Fire in DVD (2)
Have you switched yet? (84)
Optical Audio A-B Switch (1)
