and I don't know which is causing it.
In order to get the mic to work I can't push it all the way into the sound card.
I gotta pull it part way out, and wiggle it around until I get it to work. I am testing it in Netmeeting, the audio setup wizard and the sound recorder that comes with WIN98SE.
The sound card is a Creative Soundblaster Live Value, and the mic is an Andrea ANC-600.
What are your thoughts on this ?
If I had another soundcard, I might try replacing it, or if I had another mic, I might try that.
your suggestions are gratefully accepted.
thanks
