I use the following environment.
SB Audigy-->Optical Digital I/O 2(enables optical and coaxial ouput/input)--> optical, coaxial input to Z680.
Z680 does detect AC3 or DD signal whenever I play AC3 divx or DD DVD disc. the problem is whenever I navigate though the movie, Z680 redetect the signal automatically, detect stereo signal, then after skipping some part of the movie, Z680 detect digital signal again.(of course this happens in less than a second) whenver this happens I hear this loud "Pops and Clicks" on my speaker. Now this pops and clicks
is much louder than the sound thats occurs when I switch the input.
I did read the following article about common spearker problem
http://www.logitech.com/index.cfm?pa...9&languageid=1
According to the article, the main cause of this Pops and Clicks soud is
"Interrupts in the Digital Bitstream". It also statest that "This behavior generally occurs with older software and older players, but is uncommon on most modern equipment. "
Now I dont regard my SB audigy as unmodern equipment. I use the latest Codecs for
my AC3 DIVX and windvd 4 platinum for playing DVD.
Someone else who has Z680 and MAYA 5.1 GOLD soundcard also has the same problem.
Is this "Pops and Clicks" behavior totally normal?(which I dont think so)
someone help me plz.
