! C:\Documents and Settings\Tek Slayne\Local Settings\Temp\rse.swat1.r00: You need to start extraction from a previous volume to unpack rse.swat1.bin
! CRC failed in rse.swat1.bin. The file is corrupt
It gives the first message when extraction starts, the second when I press cancel. It ask for the next file, which I also have to be unrared, but it the same deal with it.
This is a movie and if you all dont condone it, Im sorry I found this site using google and I thought it was ok. Sorry if this was a problem.
