February 1st, 2004, 03:31 PM #1Member
- Jul 2003
- 46
nForce Onboard Audio Control Panel
I have a Shuttle AN35N, and using the onboard MCP audio. Is there a control panel available for download? I haven't been able to find one. Thanks for the help.
AMD 3200+
WD 200GB, Seagate 120GB
Radeon 9800 Pro, 2x512 3200
February 1st, 2004, 03:45 PM #2
Nope. Sorry. The control panel is only available for the SoundStorm™ Technology equipped mobo's.
February 1st, 2004, 03:50 PM #3Member
- Jul 2003
- 46
this seems odd, given that the MCP uses the Realtek AC'97 specs, and VIA based boards have control panel software with the same chipset...
AMD 3200+
February 1st, 2004, 03:59 PM #4
What's a "Control Panel"? My Gigabyte Nforce2 mobo (forgot the model) has the Realtek AC'97 audio onboard and has some nice tuning options with it. I could send you the drivers if you want.
Where's Lunch?
February 1st, 2004, 04:06 PM #5Member
- Jul 2003
- 46
I found a small Realtek program that has about 10 presets for the equalizer, and several other options...is the same deal you have?
AMD 3200+
February 1st, 2004, 04:07 PM #6
"What's a "Control Panel"?"
Sound Storm control panel. You have the MCP (software sound). THe SoundStorm Certified boards all use the MCP-T chip. THe -T defines it as hardware accelerated. Less cpu load= better gaming etc.
"Realtek AC'97"
That will not have anything to do with the Soundstorm control panel. That is simply the audio codec chip. It converts the digital sound to analouge. If you are useing pure digital spks. its not doing anything.R.I.P. TKOP
February 1st, 2004, 04:08 PM #7
Mine came with an EQ and the ablity to change the type of room your in. Nothing very exciting but it's a "Control Panel" of sorts.
Where's Lunch?
Wednesday... short week this week and next!
