Results 1 to 5 of 5
    Sep 2006
    2
    The drive could not be mapped because no network was found (Window XP Pro computer)
    any possible solutionfor The drive could not be mapped because no network was found (Window XP Pro computer).
    the workstation was working fine yesterday . but today the finance guy was unable to open peachtree. so i was tryin to map .. error message appeared.. ( The drive could not be mapped because no network was found).
    Advance server 2000 which is installed in a pc , which has 40 GB HD and 128 RAM. the PC server as a client and server, used by the finance departement. the server is not a domain server, it's a workgroup server. the workgroups are connected to the server .
    Member DrDave1958's Avatar
    Oct 2003
    In the middle....
    162
    What sort of network are you on?
    Is there a server?
    Do you log in to the network?
    Does your login work on a different computer?
    35,162
    65
    sounds like you just need to remap the drive.
    Like DrDave said we need more info on the network.
    Dec 2005
    Chicago USA
    2
    Make sure the workstation service is running. These search result may help,
    Symptom: when trying to map a network drive, you may receive this error: “The drive could not be mapped because no network was found”...
    http://www.chicagotech.net/Networking/ntbemapped1.htm
    Workstation Service Issues
    If a computer doesn’t have workstation service running and installed, you may have the following symptoms...
    http://www.chicagotech.net/Networkin...onservice1.htm
    I have a similar problem of which I have now moved into the realm of "baffling"
    I am using a workgroup "MYHOME"
    No server
    2 computers are connected to a Linksys router and I have a wireless laptop
    At one time all of the computers could see each other in the workgroup and all of the shares worked.
    One of the computers died and I needed to reinstall XP Pro. This was the computer that had all the printers and extra drives connected to it.
    Now, none of the computers can see any of the other computers in the workgroup.
    I have reset the router, reset the WEP security.
    I have stopped and restarted the workstation and browsing services on all 3 machines.
    Any thoughts? ideas?
    I had one person suggest turning the router into a DNS. Is that even possible? How and is that a good idea?
    -Jeff
    Last edited by Image_egamI; April 1st, 2007 at 04:13 PM. Reason: mispelling and additions
  1. mapped network drive disconnecting overnight???
    By higgledyhiggles in forum Networking and Internet
    Last Post: September 23rd, 2004, 01:12 PM
  2. mapped network drives
    By IronmanV in forum General Tech Discussion
    Last Post: March 8th, 2004, 09:10 AM
  3. Backup over mapped network drive problem
    By implexant in forum Networking and Internet
    Last Post: December 5th, 2003, 03:13 PM
  4. dial up networking and mapped network drive
    By richardlayne in forum Networking and Internet
    Last Post: March 9th, 2003, 12:02 AM
  5. cannot see mapped network drive letters in XP
    By scooterdude in forum Technical Support
    Last Post: January 9th, 2003, 09:45 PM
