Results 1 to 6 of 6
    Jan 2009
    3
    Laptop will not connect with wired connection.
    I am stumped. I am using a Linksys 2.4GHz Wireless-G router and a10/100 workgroup switch. 4 computers are on this system, 3 being wired and working fine. 1 is a HP laptop using the wireless feature and working fine. I installed a hpme wireless video security system which also broadcast on 2.4GHz. Obviously a conflict. Disabled wireless network connection on laptop and connected cable from computer 3, which goes through switch. I cannot get a working connection on the laptop using the cable. This laptop has used wired connections before in hotels and other locations. I've changed settings to match other wired computer. Reconnected cable in computer 3, amd it works. Put cable back in laptop and no go. Ive done all I know to do without success. Any ideas?
    35,159
    65
    What OS are you running? Does it give you a 169.x.x.x address?
    Jan 2009
    3
    Groundzero3. Thanks for the reply. I am running WindowsXP Professional and Yes, I do get an IP starting with 169.
    Jan 2009
    lebanon
    49
    Does your Desktops work on MAC Address access? if no then restore the Linksys or install a firmware.
    Regards, KAD
    35,159
    65
    Mac address restrictions only affect wireless clients connecting to the wireless.
    dmurphy42 do you get a link light on the network card when you plug into the router? Have a you tried a different network port or a different cable?
    Jan 2009
    3
    GroundZero3
    I changed network ports and that solved the problem. So simple--but not if you do not know what to do. Thanks. I appreciate your help and guidance.
  1. Connect wired PC and 360 to apartment's free wireless?
    By satire in forum Networking and Internet
    Last Post: October 12th, 2008, 12:57 PM
  2. Using 2 Routers to connect two wired networks
    By tdsluss in forum Networking and Internet
    Last Post: May 29th, 2008, 09:28 PM
  3. Share a wireless connection with wired?
    By JohnE. in forum Networking and Internet
    Last Post: June 27th, 2007, 08:04 PM
  4. Wired Linksys Router not Connection
    By mldapril17 in forum Networking and Internet
    Last Post: June 1st, 2005, 11:54 PM
  5. Wired and wireless connection question.
    By RAR in forum Networking and Internet
    Last Post: January 11th, 2005, 09:27 AM
