Results 1 to 13 of 13
    Nov 2003
    staten island, ny
    97
    Question USB or internal wifi card?!
    I have a PC that I am going to make into a HTPC and I can't run a network cable to it, therefore need to use wifi.... question is; PCI card (not PCI express) or USB adapter for wifi? which is better/faster?
    Jan 2003
    Outside the box
    8,663
    4
    Generally, a pci card is going to give you better speeds and more reliability overall.
    Personally I've never had good luck with USB wifi adapters. They might be fine for basic browsing and intermittent use but every time I've had one as a main adapter it has been nothing but headaches.
    Be a Liberal, blame everyone else!!
    Banned
    Feb 2009
    KFNL FS2004
    11,886
    And yet so many people swear by those stupid USB adapters. I always thought they were junk.
    Nov 2003
    staten island, ny
    97
    thats what I thought as well
    Banned
    Feb 2009
    KFNL FS2004
    11,886
    I may be mistaken, but I think the reason for crappy performance with USB WIFI adapters is due to heat.
    Millwright stroyal's Avatar
    Dec 2002
    New Hampshire
    8,189
    Not heat, they have problems.
    I don't know why, but there are many posts about them not working.
    You won't find many, if any, posts about PCI cards not working, unless they are broken.
    I know many people that never had a problem with a USB network device, but I also know many that have.
    It is not worth the hassle, if you have any other kind of choice.
    Hard Sayin Not Knowin
    NOVA
    35,162
    65
    I bought a Cisco USB wireless card a few months ago just to see if anything has improved and I was still having random disconnecting issues (like all the other usb cards ive tried)
    If you can do internal I would suggest that route
    Smile. It's easy. :) paul9's Avatar
    Aug 2003
    Gateshead U.K.
    13,384
    Another vote against USB here. I have better signal and connectivity with PCI, every time.
    Amazing Member truckpuller's Avatar
    Jan 2004
    Verona Missouri
    6,438
    I had a cisco valet usb adapter and had problems so now i have an internal PCI card and my problems went away.
    USA
    18,792
    My one and only USB wireless (Bluetooth aside) experience last year wasn't so great either, bought a Rosewill Wireless N capable USB adapter to use in the basement for a PC, located right under my room where the Router is located.
    no matter what I had the USB adapter set for, I could never get a solid connection.
    Meanwhile I've used PCI Wireless in the basement before and though had a slow connection, it was able to connect fine.
    Even using my Sony PSP with older Wireless B, can connect to the router from outside the house in the garage.
    Only thing I can think of is the USB device.
    But the Nintendo Wii also connects via USB wireless, and does so flawlessly, though at reduced speeds, but is able to connect fine. But that could just be the device and its OS/Firmware that the Console uses/runs, which might be more stable than Software on Windows on a regular USB adapter.
    Intel Core i5 4690K//CM Hyper 212 Evo/2x Akasa Viper R 140mm//EVGA Z87 Stinger//8GB Avexir DDR3 2133MHz//MSI GTX 760 2GB//XFX XTR 550W//Thermaltake Core V21//Win 8.1 64-bit//Seagate ES.3 1TB 128MB Cache 7200RPM, Seagate Barracuda 1TB 64MB Cache 7200RPM
    USA
    18,792
    However, I have worked on the odd PC now and then for a friend and had no troubles connecting a fast stable USB wireless connection to a home network and internet before.
    So for me, my luck has been 50/50. Versus 100% for PCI/PCI Express or Embedded connections for Wireless.
    USA
    18,792
    nevermind on the Wii/USB comment, I forgot its built in, I was thinking about the USB wireless stick for one of my controllers on the console for some reason.
    Jan 2003
    Outside the box
    8,663
    4
    Just to throw this out there...In no way am I saying all Wireless USB adapters suck nor am I saying all PCI cards magically work great. I've used a few pci cards that suck as well but they were far and few between. Where as I've used very few USB adapters that worked up to my expectations.
    You can get bad pci cards, and not all of them are created equal. Just make sure you buy from one of the better companies and read reviews. Especially take into consideration driver support for whatever OS you'll be running.
  1. Using cellphone antenna booster for internal wifi?
    By GH0STce11 in forum Networking and Internet
    Last Post: March 9th, 2007, 12:57 AM
  2. Mounting internal wifi antenna
    Last Post: September 20th, 2006, 05:43 PM
  3. Wireless---[USB Stick VS WiFi Card]
    Last Post: January 28th, 2006, 09:54 PM
  4. USB internal card reader problem
    By EOD in forum Technical Support
    Last Post: July 15th, 2005, 01:22 PM
  5. INTERNAL usb hub Front access, INTERNAL usb hub Rear acess both 24$ shipped
    By STAT in forum Traders Forum: Buy, Sell, Trade
    Last Post: September 21st, 2002, 01:14 PM
