Results 1 to 9 of 9
    May 2012
    2
    Computer Won't Connect to Wireless
    Hello, I've never used this forum before but I'm hoping someone can help me. I recently purchased a Netgear N150 wireless router which I hooked up to the Ubee D3.0 modem I have installed from Comcast. The router is hooked up to the main computer, which runs fine, and my laptop can also connect to the network just fine. However, I have another desktop upstairs that won't connect. It is a Dell running Windows XP and I installed a Dynex Enhanced G Desktop Card. I installed the drives for it and it seems to run fine. The program picks up on the wireless signal of the router, saying it has an excellent signal, but it won't actually connect to the router. I have contacted Dynex and they say that since the card is picking up the signal, it is not a problem with the card. I also tried contacting Netgear but they have yet to respond. The computer is currently set up for a dial-up connection (it's my grandma's computer, and I'm trying to get it set up on the wireless I installed) so I don't know if that is causing interference, or if the wireless card isn't compatible with the router. I have no idea what's going on and any help would be greatly appreciated!
    Millwright
    Dec 2002
    New Hampshire
    8,189
    Welcome to TechIMO!
    Dynex is Worst Buys brand name. Need I say more?
    Oh alright.
    Is this a USB device?
    Have you tried temporarily moving the computer next to the router, to see if it is just distance?
    I'll say it again, USB works fine with everything, but wireless.
    I don't know why, but I know many people never have a problem, but many do.(we get posts all the time about USB wireless, not working.)
    PCI cards are cheap.
    Newegg.com - Computer Hardware, Networking, Wireless Networking, Wireless Adapters, PCI
    With a PCI wireless card, problems, are almost non existent.
    Taking a computer apart, is really simple for me, so there is no reason what so ever,for me to have a USB network device ever.
    Hard Sayin Not Knowin
    Banned
    Feb 2009
    KFNL FS2004
    11,885
    Go to the control panel and choose Network adapters, now right click the dial-up connection and choose disable. Did you set any type of encryption up for the WIFI network?
    Banned
    Feb 2009
    KFNL FS2004
    11,885
    Welcome to TechIMO!
    Oh alright.
    I looked the card up and its a PCI card. Dynex DX-EBDTC 802.11g Enhanced Wireless-G Desktop Card Overview & Specs - Adapters/NICs - CNET Reviews
    Millwright
    Dec 2002
    New Hampshire
    8,189
    I have 2 Dynex devices. 50/50 failure rate.
    A wired laptop network card the was so ridiculously cheap, I bent my Worst Buy rules.(never buy from Worst Buy)
    I also have a wireless router, that was given to me, that the wireless portion is dead.
    I'm told it only lasted a few weeks.
    Millwright
    Dec 2002
    New Hampshire
    8,189
    Thanks Taxman
    Well we can't blame USB then.
    This is why cheap stuff sucks, as it could be either the card, or the installation/drivers
    What operating system do you have?
    I haven't had to install drivers for a network card, wired or wireless, since XP came out.
    On board needs drivers sometimes, like the Dell 3000 I programed the other night.
    I slapped an old Netgear wireless in the same computer, and it just works.
    Look in device manager.
    If the card is in alarm, simply, un-install it in device manager, and restart.
    Go to windows update, and see is they have a driver under devices.
    Xp has hundreds, of Network card drivers, pre-installed.
    Edit
    How did you install the drivers?
    Many driver programs, are a program that installs, within windows.
    The other type, installs on start up when Windows discovers the device.
    Which type do you have?
    If it is the program type, you ignore windows pleas to install them on start up, and cancel through to the desktop.
    May 2012
    2
    So I ended up finally getting in contact with my parent's tech guy and he told me to change the security settings of the router from WPA-2 to WEP because older cards sometimes aren't compatible. Turns out that fixed it! Thank for your help guys!
    Banned
    Feb 2009
    KFNL FS2004
    11,885
    I kinda figured that that's why I asked if you were using any kind of encryption. Use this page to create a good password. https://www.grc.com/passwords.htm
    Millwright
    Dec 2002
    New Hampshire
    8,189
    Can't say I thought of that, even though I had that problem with 1 of my Son in Law's computer a few months back.
    Glad you fixed it.
  1. IE will not connect to wireless
    By Deistic1 in forum Technical Support
    Last Post: September 29th, 2009, 05:53 PM
  2. Using a second wireless router to connect to connect up an XBox
    By james789 in forum Networking and Internet
    Last Post: April 27th, 2008, 03:34 PM
  3. Connect to two wireless networks at once?
    By byunews in forum Technical Support
    Last Post: April 1st, 2005, 07:17 PM
  4. Replies: 14
    Last Post: May 30th, 2003, 10:35 PM
