Results 1 to 12 of 12
    Senior Member gentry_joey's Avatar
    Aug 2003
    637
    Wireless Networking
    I need to know what I need to buy to get a outdoor wireless network thats a lil less than half a mile or so. Maybe a quarter mile. I need it so I can network with my friend so we can play lan games.
    Jul 2002
    edit - gone north
    218
    google search and then look for hardware that actually runs on your hardware.
    From experience - some stuff just does not work in the real world.
    And for your money - 802.11B is fast enough! -
    Centurion - From Canada
    Member cyclist110's Avatar
    Jun 2003
    Calgary,AB
    176
    Remember that the further the distance the slower the speed.
    C.
    C.
    Jul 2002
    edit - gone north
    218
    true - but as you have guessed or can guess - when checking speeds - you only need to be fast as the slowest link in your network - If you are using 802.11b - you are at theoretical 11mps - actual is slower - yuo can get a speed estimate from most manufactures sites which give you signal strength verses speed connectivity -
    One test recently performed was to link to a encrypted wireless site - and see what we could get for a theory - well 50% was the lowest strenght - and this was good for a 8mps speed - which around here is 20 times the fastest landline speed -
    The lenght was 18 kilometers - about 11miles
    cheers - C
    NOVA
    33,788
    46
    is there a line of sight with where you want to connect?
    how much are you willing to spend?
    Carrollton, Texas
    178
    This will help also.
    http://cantenna.com
    NOVA
    33,788
    46
    for alittle bit more than 50 bucks he could get something better than a cantenna, plus i heard bad reviews about those who have purchased from the site.
    Member SunDizzle's Avatar
    Feb 2003
    Eastern PA
    394
    Hey, are those available every where???
    If so that's the hottest thing out there for tech....
    wow, I am truely amazed
    Fill cups like Double D's!!
    San Diego, CA
    6,399
    You can get a 200mW wireless bridge if you wanna connect your LAN to his... Or a 200mW access point and you can both connect to it. The bridges can be rather expensive, a quick google search brought up one that was $300+ but had a range of 15 miles! A quick search on 200mW AP's and I saw some 802.11B AP's for about $90. I don't think you'd get 15 miles, but if 200mW PC cards can do 4000' i'm sure the AP's can do atleast that which is more than enough range for your needs.
    Aug 2003
    637
    well this has to be outdoors and i am buying all the networking items. This is my deal. Also I only need a mile or less.
    No pants, Wearin'a Helmet MitaDC's Avatar
    Aug 2003
    Coeur D' Alene,Idaho
    3,459
    How much $$ u willin to spend?
    Dr. Cox -Newbie, Stay. Oohhh what a good boy you are, Newbie..... DEAR GOD JUDY HOW MUCH PRODUCT DO YOU USE?
    J.D -None. It's like this when I wake up
    Jul 2002
    edit - gone north
    218
    I hate to say this - but a cardboard catchow box and a USB SMC adapter is all we are using.
    You have to follow a pattern - search for box antennas - and about a $1 worth of tin foil, and some duct tape, keep thick bandaids around in case your bad with a box cutter.
    I don't spec a dB gain - but the latvians claim 24 to 32 dB
    C
