Thread: Netopia Tech Note HELP!!!
June 8th, 2004, 12:37 PM #1Junior Member
- Jun 2004
- 2
Does anyone have or know where to find the Netopia tech note NIR_050? Netopia has pulled it from their site and cannot release it because of some contractual agreement with an ISP. I'm trying to replace two damaged R7100C routers that were connected back to back and I can't find any information regarding this type of installation. I've tried all of the parameters set per the existing routers and have tried setting the parameters identical to the one example that I could find searching the net. I think it may be a matter of the WANlet firmware version in the replacement routers but can't comfirm it. help!!!
June 8th, 2004, 01:02 PM #2
In case this is not the example you tried... http://isp-lists.isp-planet.com/isp-.../msg00187.html
June 8th, 2004, 03:10 PM #3Junior Member
- Jun 2004
- 2
Back to Back
Thanks, That is the only example that I can find and for some reason I cant get it to work with the new routers. Any suggestions would be greatly appreciated.
Cable Modem and NIC
By haxxorpoop in forum General Tech DiscussionReplies: 9Last Post: November 29th, 2003, 12:41 PM -
Hello, I'm new to Techimo forums!
By Good Charlotte in forum IMO CommunityReplies: 45Last Post: July 23rd, 2003, 02:28 AM -
Timbuktu connecting
By Vagabond in forum Networking and InternetReplies: 4Last Post: May 28th, 2003, 12:56 PM -
How to block an IP in the router?
By Mr. NoOne in forum Networking and InternetReplies: 7Last Post: March 14th, 2003, 02:08 AM -
Alternatives to PC Anywhere
By ctaylor in forum Applications and Operating SystemsReplies: 20Last Post: June 21st, 2002, 12:46 PM
This method might be heplful provided you have lots of time to enable, restart, enable, restart, etc WmiPrvSE.exe taking CPU 100%, Windows Update problem - Windows 7
BSOD on Vista Home Premium
