There is a preferred network adapter setting within XP. It may help, but it may not depending on the game. Some games also have a network card choice setting as well.
go to: Control Panel, Network Connections, Advanced, Advances Settings
Then on the Adapters and Binds tab, you should see a Connections window, there you can change the order of the connections and it may help.
