Using USB Camera as security camera Via a Wired Network...
Currently Active Users: 1713
Discussions: 200,933, Posts: 2,379,194, Members: 246,298
Old January 26th, 2005, 11:29 PM   Digg it!   #1 (permalink)
Hello,
I have 5 computers (1 Win XP, 3 Win ME and 1 98 system) setup in my wired home network, I also have 2 usb cameras-
Is there a way that I can attach the camera (leave it on all the time) and view it through another computer on my LAN, maybe even tape the scene every few minutes or seconds or even when motion is detected.
I'm sure there must be some software or tweak can be done but I've had no luck finding it online.
Any info would be greatly appreciated.
APRILRAIN is offline   Reply With Quote
Old January 26th, 2005, 11:31 PM     #2 (permalink)
Did you try Google yet?
Siliconjunkie's Avatar
Send a message via AIM to Siliconjunkie
Yeah, there is webcam software that is motion sensing.
I used one of them a few years ago. Worked pretty well, but you have to be careful where you point it.
Let me see if I can find what I used.
Siliconjunkie is offline   Reply With Quote
Old January 26th, 2005, 11:33 PM     #3 (permalink)
Si vis pacem, para bellum
daveleau's Avatar
Send a message via ICQ to daveleau Send a message via AIM to daveleau Send a message via Yahoo to daveleau
There's quite a bit of software that will do this. Some record constantly and only keep the segments where there is movement. Some have motion detection tech to start recording when there's movement. Some record constantly and save everything.
http://www.deskshare.com/wcm.aspx
http://www.google.com/search?hl=en&q...curity+program
daveleau is offline   Reply With Quote
Disable scanner & cam wizard? DSM Storm Applications and Operating Systems 2 October 3rd, 2003 08:06 PM
Can you recommend me some great digital cameras? kpnet Multimedia and Audio 4 August 1st, 2003 12:35 AM
Printers & Memory cards sas978 General Tech Discussion 4 January 16th, 2003 09:01 AM
Digital camera hacking? dunbar General Tech Discussion 2 September 11th, 2002 02:34 PM
Anybody using Kamera with KDE3? otheos Applications and Operating Systems 3 June 8th, 2002 03:58 AM
Is It Just Me? (2886)
Wireless Televisions. (5)
Obama the Muslim (14)
favorit (1)
Regular Build (3)
Fire in DVD (2)
Have you switched yet? (84)
Optical Audio A-B Switch (1)
