Thread: winme to xp lan connection
May 7th, 2005, 05:25 PM #1
i cant seem to get a connection. i know my nics are good and my cat5 cable is good, but i cant connect to each pc. my status says im connected. when i try to ping my winme pc i get host unreachable. i turned off firewall on xp pc but still nothing. ive been out of the network scene for awhile and im probably just overlooking something. maybe someones just going to have to walk me through this before i take a bat after both of them.
May 7th, 2005, 06:08 PM #2
im no network master, but try setting up the IPs manually to like 192.168.0.100 and 192.168.0.101 with a gateway 255.255.255.0... sometimes XP gets fussy with these things.
might work...AMD Opteron 146 2.8ghz 280x10
1GB GEIL ONE S PC3200
DFI LanParty UT NF4 Ultra-D
ATI X1800XT @ 700/800
Enermax Noisetaker 485W
BigWater SE
May 7th, 2005, 06:16 PM #3
hey ^, i tried that and lost connectivity, switched back to automatic acquire ip and got connection. but i still cant see either pc, cant ping either pc also. this is bugging the crap out me. ive setup networks before and haven't had near this much trouble. maybe its sp2 or maybe its just me.
May 7th, 2005, 07:18 PM #4
Are they plugged into a router? Do you have DCHP enabled on the router to assign the IP addresses? Can you ping the router?
May 7th, 2005, 07:48 PM #5
no router, im using crossover cable. found some of my problem. some services were disabled. now if i can only get my pcs to see each other. it shows local area connection is connected.
May 7th, 2005, 07:52 PM #6Ultimate Member
- Oct 2001
- 10,821
you might have to set the WinME machine to have the "primary network logon" to "client for microsoft networks"
right click "my network places"/properties and youll see it"Even a fool is thought to be wise if he is silent"
May 7th, 2005, 08:09 PM #7it is set to client for microsoft networks. at first when i pinged the winme pc, i was getting host unreachable, now im getting request time out. so im getting closer. also i set the winme pc to obtain ip automatically and it was getting an ip of 169.xxx.xxx.xxx the xp pc had a range of 169.xxx.xxx.xxx so i manually set the ip for the me pc.
Originally Posted by John Prophet
May 7th, 2005, 08:31 PM #8
post an "ipconfig /all" from the xp machine, and a "winipcfg" from the Me machine.
May 7th, 2005, 08:53 PM #9*****
The final legacy of the United States will be that in the end liberalism shamed & destroyed the heritage of this great nation. How sad as I see no turning back. When in Rome ..
May 7th, 2005, 09:05 PM #10
here you go.
http://www40.brinkster.com/kenboyles72Last edited by kenboyles72; May 7th, 2005 at 09:26 PM.
May 7th, 2005, 09:32 PM #11
Your ip addresses are on different subnets. 192.168.0.1 and 192.168.1.101. Make the 192.168.0.1 this 192.168.1.102 and see what happens.
And make sure the workgroup name is the same on both pc's.
May 7th, 2005, 09:47 PM #12
changed the ip, still nothing.
May 7th, 2005, 10:05 PM #13Ultimate Member
- Oct 2001
- 10,821
did you change the workgroup name so they matched?
on the xp machine....are the "computer browser" and "server" services set on "auto"? if not try em on auto by running "services.msc" and setting them etc
also of course on the xp machione check and make sure "client for microsoft networks" is installed.....I suppose it is in the same place or close as where you checked on the Me box.....we had this huge thread once trying to fix a guys issue and it was that his XP box was missing "client for microsoft windows" (which I never thought of)"Even a fool is thought to be wise if he is silent"
May 7th, 2005, 10:11 PM #14
browser was set to auto, server was set to manual but was running. workgroups are both mshome. client for microsoft windows is installed.
May 7th, 2005, 10:13 PM #15Ultimate Member
- Oct 2001
- 10,821
and your SURE u got a crossover cable??
or do you just have a straight cable????"Even a fool is thought to be wise if he is silent"
May 7th, 2005, 10:22 PM #16
yeah its crossover, did it myself
May 7th, 2005, 10:24 PM #17Ultimate Member
- Oct 2001
- 10,821
hmmmmm
"did it myself"
maybe you should try another one for the heck of it"Even a fool is thought to be wise if he is silent"
May 7th, 2005, 10:44 PM #18
according to my diagram its right
on one end of the crossover cable its wired straight, the other is wired crossover(or null)Last edited by kenboyles72; May 7th, 2005 at 10:47 PM.
May 7th, 2005, 10:52 PM #19Ultimate Member
- Oct 2001
- 10,821
I would make another cable though just for kicks...in case one of the contacts isnt great or something
May 7th, 2005, 11:08 PM #20
remade connections, no change.
Problem with lan connection
By roosta21 in forum Networking and InternetReplies: 16Last Post: May 11th, 2005, 12:43 AM -
[FAD] LAN Connection?
By kenboyles72 in forum Distributed ComputingReplies: 2Last Post: May 7th, 2005, 04:01 PM -
Ethernet LAN connection problem
By decnug in forum Networking and InternetReplies: 15Last Post: March 22nd, 2005, 01:24 AM -
remote lan connection?
By VHockey86 in forum Networking and InternetReplies: 14Last Post: September 3rd, 2003, 02:24 PM -
Setup win2k LAN connection
By Leigh26 in forum Networking and InternetReplies: 2Last Post: May 8th, 2003, 07:01 PM
found the drive and it is listed as unallocated space. i'm just wondering if it sees my dual boot linux partition.
How do i delete a partition that i...
