Page 1 of 3 1 2 3 LastLast
Results 1 to 20 of 44
    Ultimate Member NightRise420's Avatar
    Oct 2004
    Cali
    1,577
    My Internet Connection Speed @ 1Mbps! Help!
    Well...the title saids it. After moving the computer to upstairs, the rate dropped from 2mbps to 1mbps and the connection drops sometimes. I have the Linksys Wireless-B (802.11b) Router and on my computer.... i think and i have the Belkin Corporation Wireless adaptor that receives the signal. I thought the wireless signal can be reached far away and im wondering why the speed has dropped significantly. I'm wondering if its the crappy wireless receiver. Will it help if i get a Linksys USB Bluetooth or get a Linksys PCI adaptor? I need help plz =)
    Live Fast, Die Young, Dont Forget, Dont Regret
    Banned
    Dec 2005
    1,465
    Distance has to be considered here without knowing the actual range limitations on the
    wireless setup you have. The materials inbetween can also have a bearing. The materials in
    the walls and floor as well as any large appliances can reduce signal strength regardless of
    the make and model router you are using. You could go out and spend twice as much on a
    totally different setup only to see the same thing happen again.
    NOVA
    33,807
    46
    what electronics do you have around the router and the computer?
    Do you have the latest firmware for the router?
    Oct 2004
    Cali
    1,577
    Around the computer, i have a printer, around the router, its in a small office room surrounded by walls, lamp. Whats a firmware?
    Aug 2003
    Gateshead U.K.
    11,322
    Firmware is the operating system built into a device. Like the BIOS on the PC, it can be updated to cure some problems, and possibly cause new problems.
    Oct 2004
    Cali
    1,577
    even tho the signal is low, why isnt my speed at 11mbps?
    Ultimas w00t! Mastah... vikeor's Avatar
    Warsaw, Poland
    6,443
    11mbps? now are you talking about ur network speed or internet speed?
    AMD Opteron 146 2.8ghz 280x10
    1GB GEIL ONE S PC3200
    DFI LanParty UT NF4 Ultra-D
    ATI X1800XT @ 700/800
    Enermax Noisetaker 485W
    BigWater SE
    Aug 2003
    Gateshead U.K.
    11,322
    Quote Originally Posted by NightRise420
    Because radio signal strength drops greatly over distance, and the walls etc. are like even more added distance, the data has to be constantly retransmitted or transmitted at lower speed in the first place to be recognised at the recieving end. Aftermarket antenna are available for some transmitters, and can make a lot of difference.
    Oct 2004
    Cali
    1,577
    Quote Originally Posted by vikeor
    I'm talking about my network speed where it saids Speed: 1Mbps.
    Oct 2004
    Cali
    1,577
    Quote Originally Posted by paul9
    Can u find me some Antennas for my Linksys BEFW11SR Broadband router? I'm hoping this will make my signals better.
    Oct 2004
    Cali
    1,577
    also whats TNC and SMC?
    Aug 2003
    Gateshead U.K.
    11,322
    Is the current antenna on a BNC plug or similar?
    Try http://www.newegg.com/Product/Produc...&Go.x=0&Go.y=0
    Oct 2004
    Cali
    1,577
    will adding a high gain antenna make my network speed higher?
    Aug 2003
    Gateshead U.K.
    11,322
    If the signal path improves, then it should make a fair bit of difference. However, you will probably need a decent antenna at both ends.
  15. #15
    Banned
    Dec 2005
    1,465
    You will definitely have to have a boost at both ends to see any good results there. A loss
    of signal strength has already been the main reason why your speed has dropped. Boost a
    living heck at both ends may see some much needed improvement. Do you remember those
    old cd radios with directional antennas? What happened when you moved away from this or
    that contact to speak to another? The answer is obvious. Boost reception and transmission
    at both ends to get improved results.
  16. #16
    Oct 2004
    Cali
    1,577
    I have a linksys Broadband router.
    http://www.newegg.com/Product/Produc...82E16833164109
    is that a good antenna?
    or this one?
    http://www.newegg.com/Product/Produc...82E16833124155
    the second one seems to have a bad review on it....
  17. #17
    Oct 2004
    Cali
    1,577
    http://www.newegg.com/Product/Produc...82E16833156010
    oh that one seems good for the price
  18. #18
    Aug 2003
    Gateshead U.K.
    11,322
    Personally, I'd give GroundZero a nudge, as he likes to do a bit wireless work.
  19. #19
    Oct 2004
    Cali
    1,577
    i guess ill have to wait for someone to recommend me an antenna
  20. #20
    Human voltmeter DanU's Avatar
    SF Bay Area
    4,214
    I think you mean SMA instead of SMC? SMC is a company that makes networking equipment .
    TNC and SMA are types of RF connectors, similar to the "F" connector used for TV coax cable and the BNC connector used on certain monitors. Most routers use the "reverse" SMA connector. Whichever one your router uses, you'll want to make sure that any antenna you buy uses the same, otherwise you'll need some kind of adapter.
    First of all, have you tried reorienting the antennas on your router? Dipole antennas work best when they are oriented perpendicular to the direction of travel. A simple reorienting may boost your signal enough to establish a solid connection.
    If this doesn't help, THEN you can try buying higher gain antennas. Generally, the higher the gain, the stronger your signal will be, but the narrower the "beam" will be. Any points located outside the beam will see weaker signal (which is often a good thing). Since you already have some signal then you may just need a few dB of gain. A pair of replacement high gain antennas could be the thing you need:
    http://www.newegg.com/Product/Produc...82E16833124156
    [edit]
    I forgot that you moved your computer upstairs. These antennas will have a narrower beamwidth so orienting the antennas will be more critical. If you don't do it right, your signal strength will decrease!
  1. Internet Connection Speed
    By JimRune in forum Networking and Internet
    Last Post: April 28th, 2005, 09:00 AM
  2. how to speed up dial-up connection
    By jervic in forum Networking and Internet
    Last Post: October 9th, 2004, 12:35 PM
  3. locking connection speed?
    By Starfury_2260 in forum Networking and Internet
    Last Post: December 26th, 2003, 01:30 AM
  4. Connection Speed?
    By Linkin' Park in forum Networking and Internet
    Last Post: May 9th, 2002, 06:21 PM
  5. Connection Speed
    By SysRq in forum Networking and Internet
    Last Post: February 26th, 2002, 11:52 PM
