Results 1 to 6 of 6
    Ultimate Member amdkt7's Avatar
    Nashville, TN
    1,942
    Cable internet keeps going dead...
    I am using a wireless router to share an internet connection. I'm using a router attached to the cable modem. I can log on to the router just fine even when the connection is dead.
    Connection Method: Direct
    Broadband Modem : Connection OK
    Internet Connection: Inactive (I can't remember exactly what it says when dead).
    DHCP Client: Enabled
    Lease obtained: 0days,0 hrs,0 minutes
    Remaining lease time: 0 days,0 hrs,0 minutes
    Cannot find DHCP server.
    The fix is easy, simply power down the modem and the router for a full minute, then repower. This always works, but is a real pain because it is in another part of the house that I don't always have access to.
    This is a new problem, has been working fine for seveal months.
    I'm about to buy a new router just to see if that makes the problem go away.
    Asus M4A785TD-V EDO, Phenom II X4 945 Deneb 3.0GHz 4 Gig DDR3 1333 Win7 64 Home
    NOVA
    33,881
    46
    plug the computer directly into the cable modem and see if the connection fails.
    also i would look into a firmware update for the router.
    Banned
    Dec 2005
    1,465
    Some service providers have been finding issues with the wireless routers over the older model dsl hubs. This can be attributed to drivers on occasion while interference from a few
    things like distance and what is inbetween electrical and otherwise.
    Ultimate Member jrsweger's Avatar
    Oct 2004
    Upstate NY
    1,645
    You say you are sharing an internet connection. Does the shared connection have the same difficulties that you are having? You may want to turn off DHCP and use a static IP for your connection instead.
    Nashville, TN
    1,942
    Last I checked the firmware was upto date.
    Both computers go down at the same time, theirs has the direct connection to the router.
    I have not had a chance to try removing the router (hard to get to), but if I get a chance to do that I will.
    The Comcast tech told me it was do to a build up of static....
    Perhaps it is the modem that has the problem.
    I'll see if I can use a static ip, I'm not sure if I can do that. The IP to the modem is provided by comcast, but the router I guess has it's own too?
    Oct 2004
    Upstate NY
    1,645
    If both connections are going down simultaneously, do what GroundZero3 said above.
  1. Rogers cable internet vs. Bell DSL internet
    By SeanC in forum Networking and Internet
    Last Post: November 8th, 2011, 01:44 PM
  2. n00b question... Is RG6 Coaxial Cable proper for Cable Internet??
    By ChestLick16 in forum Networking and Internet
    Last Post: December 21st, 2005, 02:20 AM
  3. cable internet
    By natbeys in forum Networking and Internet
    Last Post: September 2nd, 2004, 07:55 PM
  4. Cable Internet Problems
    By Javonovich in forum Networking and Internet
    Last Post: August 24th, 2004, 10:21 PM
  5. HDD Dead? or ide cable?
    By MMock in forum Technical Support
    Last Post: January 30th, 2002, 06:23 PM
