August 3rd, 2006, 06:40 PM #1
Some help with Linksys BEFW11F4 wireless router please???
Hi guy's,
I have a Linksys BEFW11F4 wireless router at home. I am having problems with poor signal strength in the other rooms, I have concrete walls. Do you guy's know if the HGA7T(Linksys made) anntenas can help me out with this problem?
Do any of you have a pair and can recommend it to me?
Thanks.
August 3rd, 2006, 07:55 PM #2
It might help some but concrete and wireless dont play well together at all.
How far is the computer from the router?
August 3rd, 2006, 08:33 PM #3
August 3rd, 2006, 11:56 PM #4
You might have better luck with the Linksys Wireless-G Range Expander which will also work with 802.11b. Linksys used to make a signal booster for 802.11b (I have one), but it doesn't show on their website any longer. Maybe you can find a used one somewhere. Or just go with the range expander.
You can't fix stupidity.
August 4th, 2006, 12:10 AM #5
You can go out and also buy the Linksys WRT54G and download a third party firmware called HyperWRT that will allow you to increase your power output.
Also radioshack carries Linksys compadible upgrade antennas for around 20 bucks.
http://www.hyperwrt.org/
August 4th, 2006, 07:15 AM #6
Increase your power output is not always a good idea and can actually cause more signal problems.
More does not always mean better
August 4th, 2006, 10:07 AM #7
Thanks guy's I will take these reply's under consederation.
Linksys Wireless B Router Reccomendations
By Blackhawk786 in forum Networking and InternetReplies: 5Last Post: July 25th, 2005, 11:31 AM -
Dlink Wireless A-card - Linksys Wireless Router
By venomxx in forum Networking and InternetReplies: 11Last Post: November 3rd, 2004, 12:57 AM -
Linksys Wireless G Router
By mtesta1214 in forum Networking and InternetReplies: 1Last Post: July 18th, 2003, 03:13 PM -
Wireless Linksys Router setup?
By Winos2Mac in forum Networking and InternetReplies: 6Last Post: July 22nd, 2002, 10:06 PM
Hi Friends, One of my friend tell me about some shows and movies. you can also enjoy them here: Watch GI Joe Retaliation Online Watch Iron Man 3 Online Watch The Hangover Part III Online Grimm...
