Wired/Wireless Help.  | | |
January 8th, 2007, 08:30 AM
Can anyone help me with this problem. I keep trying to connect my computer to my router (link sys wrt54g) and it sends and receives, but i ant assess anything. So i tried the same Ethernet cord on my laptop and it works. So i tried wireless on my desktop. AGAIN it sends and receives, i can ping websites. but i cant assess anything, not even 192.168.1.1 .. Can anyone help me THIS IS DRIVING ME NUTS!
I have a dell E521. I tried drivers and such. No luck. If anyone wold help id appreciate it. |
January 8th, 2007, 03:20 PM
| | Human voltmeter
Welcome to Techimo!
Can you be more clear on what exactly the problem is? You mentionend being able to connect via wired ethernet on your laptop, then say you can't connect wirelessly on your desktop??? Are we talking about your laptop, or your desktop that is having the problem? |
January 8th, 2007, 04:11 PM
My desktop is having the problem. I try connecting for example to google.com . When i try i see that it sends and receives but it cant connect. On cmd i can do " Ping -t 'google.com' " and it shows me the ip address, and the response time which in under 50ms.
I tried connect wired AND wireless. Both resulted as explained above.
Hope that clears it up & looking forward to a response. |
January 8th, 2007, 04:33 PM
| | Banned
have you tried updating your router firmware? |
January 8th, 2007, 04:38 PM
| | Super Stealthy Moderator
What browser,operating system and firewall are you using? have you scanned for viruses, adaware ect?
did this computer ever connect?
Linus Torvalds |
January 8th, 2007, 04:50 PM
Windows IE and mozilla. I disabled windows firewall, dont know if i have any others (at school atm) .
I just got the Dell E521 like a week ago, and it never was connected to internet.
EDIT: Windows Media Center 05 |
January 8th, 2007, 06:31 PM
| | Human voltmeter
Sounds like the network is working fine, but the software (IE and mozilla) are not functioning right.
Does anyone else use the computer? You may have a virus or spyware. Download and run "Hijack This" and run the logfile through www.hijackthis.de.
You are running antivirus and anti-spyware utilities, right? |
January 8th, 2007, 06:49 PM
Thanks for al the help but i got it working. One of the most simply but most affective solution ever... reformatting. thanks for the replies. |
January 8th, 2007, 06:54 PM
| | Caveat Emptor
ROFL...THE ULTIMATE WINDOWS FIX....REFORMAT AND FRESH INSTALL.  |
January 8th, 2007, 07:04 PM
don't know that that would be the simple way to go unless it was a fairly fresh install that would be hours of re-installs and updating for me
IMO troubleshooting is always the best way to go |
