Join TechIMO for Free!
Thread Tools
Currently Active Users: 2255
Discussions: 186,591, Posts: 2,226,870, Members: 230,214
Old April 6th, 2002, 11:15 PM   Digg it!   #1 (permalink)
robin801's Avatar
Send a message via ICQ to robin801
need help before i tear up my system
i have dsl with mindspring.com. i have not been able to get online all afternoon. (i had to put my laptop on dialup).
how can i tell if it is because of something i did or my service?
i called mindspring and they said that there was nothing wrong on their end. couldn't help me because i don't have their software installed(winpoet) and i am connected through a router.
then i called billing and they said that they couldn't check my bill because their computer was down.(but shouldn't affect my not being able to get on line)
my main system is running win2k.
where do i look to see if everything is alright from my end?
i added filetopia to my system last night. this morning and early this afternoon i was still able to connect. went out and came back and i haven't been able to connect since.
i unplugged the modem and router a couple of times and still nothing.
please someone help me.(i want to get my speed back)
robin
always wanting to learn something new
robin
robin801 is offline   Reply With Quote
FREE instant scan
Old April 7th, 2002, 11:44 AM     #2 (permalink)
robin801's Avatar
update to my problem. i still can't get to the internet.
under local area connection status:
status-connected
duration=00:17:00
soeed-100.0mbps
activity
packets-sent-112
recieved-18
under event viewer-
on 4/7 dhcp error
event number-1002
i had this same error on 4/6
can anyone tell me what to do?
robin
Old April 7th, 2002, 11:47 AM     #3 (permalink)
Indispensable Member
surreal's Avatar
Send a message via ICQ to surreal Send a message via AIM to surreal Send a message via Yahoo to surreal
You need to call tech support again.
Why don't you have winpoet installed? I thought you needed that?
surreal is online now   Reply With Quote
Old April 7th, 2002, 11:49 AM     #4 (permalink)
robin801's Avatar
i haven't had it installed since i added the router.(over 8 months)
i may have to take it off the router and start all over again. trying to get some help from here before i go that route.
robin
Old April 7th, 2002, 11:51 AM     #5 (permalink)
iNsAn3 mEMBER
Daft_Ghosty's Avatar
Send a message via ICQ to Daft_Ghosty Send a message via AIM to Daft_Ghosty Send a message via MSN to Daft_Ghosty Send a message via Yahoo to Daft_Ghosty
have you tried connecting through without hooking into the router.. and tried it that way..?
sorry but I don't have DSL.. I'm on cable.. and there are differeances in the 2.. so might not be able to help much..
In life one must Chill
Daft_Ghosty is offline   Reply With Quote
Old April 7th, 2002, 12:49 PM     #6 (permalink)
Mortis's Avatar
Try turning off your modem then unplugging your Router for 2-3 seconds than plugging it back in. I have to do this occassionally as I dont allow certain services to access the net. As a result, my DNS and other services (ISP related) dont update. I suspect it then does not receive update info from ISP, making it freeze and not function- it just sits there when I try to connect. I do the above and everything works fine then. I do not really know the ins and outs as to why this occurs, but do not like certain things accessing the net. I have cable, so the situation is probably a little different, but its worth a try. GoodLuck
Mortis is offline   Reply With Quote
Old April 7th, 2002, 12:56 PM     #7 (permalink)
robin801's Avatar
i had the whole system turned off all night. when i cut it back on this morning i still couldn't connect.
i tried connecting without the router but it didn't work.
i think i need winpoet installed for that to work. i don't have a modem installed in my main system.
i have a modem in my laptop. can i install winpoet to my laptop and then connect laptop directly to modem and get my laptop running on the dsl line and then hook up my other systems to the router.
laptop running winxp.
robin
Old April 7th, 2002, 01:05 PM     #8 (permalink)
Mortis's Avatar
Its a place to start.... I say try it...
Old April 7th, 2002, 01:17 PM     #9 (permalink)
robin801's Avatar
from the website it doesn't say it supports winxp.
guess i'll have to buy a modem for my system.
robin
Old April 7th, 2002, 01:24 PM     #10 (permalink)
iNsAn3 mEMBER
if it says it supports Windows 2k.. or NT it will work under win xp.. or should
Thread Tools
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
heatsink issue (8)
Is It Just Me? (492)
Why Does the MOON Grow Bigger as It.. (11)
New Mobo (16)
1 internet. 1 house. 3 computer. ho.. (10)
Connected to LAN but unable to use .. (5)
heatsink issue (8)
Hard Core Overclock (7)
FS: New Benny Hill Megaset DVD .. (6)
Computer won't start (2)
New Mobo (16)
1 internet. 1 house. 3 computer.. (10)
Request for recovary system ins.. (0)
Folderchat: The Holiday thread (111)
am2 on 939 (4)
Folderchat Weekday thread (411)
