Wired network problem
Currently Active Users: 2460
Discussions: 200,994, Posts: 2,379,932, Members: 246,362
Old February 10th, 2007, 01:49 AM   Digg it!   #1 (permalink)
Swine flu stopper
Mickwish's Avatar
Ok, bought a new house, it has two wired sockets wired between the study and two bedrooms with cat 5 and RJ-45 wall sockets. I hadn't been using them because I had wireless set up, but tested them recently. No worky. Now, I have a cable tester which send signals between the pairs, and that shows packets are being sent fine (all pairs show green). You can plug the cables in and all the sockets on the PC's and router light up, and windows sees a connection. BUT it won't get an IP, and still won't work if you set the IP manually.
I check the RJ-45 sockets today, and all the wiring seems OK and all the wires are punched down correctly. My question is: would running the cat 5 incorrectly in the roof space (eg alongside a mains electrical cable) prevent the signal from working, but allow the line tester to work?
That's my next step, to see if the roof space wiring is bad. But before I do that and get all dirty up there, thought I'd ask you lot.
I would have thought that if it's noise from electrical wiring then I would get an IP and stuff but have poor data transfer and dropouts, not no signal at all. Thoughts on that?
Mick
I don't like sigs on forums like this.
Mickwish is offline   Reply With Quote
Old February 10th, 2007, 02:09 AM     #2 (permalink)
The Macedonian Member
njolakoski's Avatar
Send a message via AIM to njolakoski Send a message via MSN to njolakoski Send a message via Yahoo to njolakoski
What are the wired sockets connected to Mick?
njolakoski is offline   Reply With Quote
Old February 10th, 2007, 02:14 AM     #3 (permalink)
Swine flu stopper
Mickwish's Avatar
I have tested them with different cables using my laptop and a router. Connecting the laptop directly to the router works; connecting via the cables (have tried various cables) and the wall sockets doesn't.
Is that what you mean, Nick?
Cheers
Mick
Old February 10th, 2007, 02:16 AM     #4 (permalink)
njolakoski's Avatar
Where do the cables(inside the wall) from the walls sockets connect to?
Old February 10th, 2007, 02:21 AM     #5 (permalink)
Instigator
Atomic Rooster's Avatar
Send a message via AIM to Atomic Rooster Send a message via Yahoo to Atomic Rooster
Is the CAT5 a crossover or standard straight through cable?
Atomic Rooster is offline   Reply With Quote
Old February 10th, 2007, 02:23 AM     #6 (permalink)
Swine flu stopper
Mickwish's Avatar
To another wall socket in another room, Nick.
I think I have it. I had looked at the RJ-45 wiring initially and it was the same at both ends. BUT... now looking at thsi website (they are Clipsal sockets) I can see that both the sockets are cross wired. The blue wires and green wires are not connected correctly. So looks like I need some new RJ-45 sockets, and I don't think I can change the wires around once they have been punched down.
Thanks for your interest, Nick. looks like I'll gonna have to get some new sockets.
Cheers
Mick
Old February 10th, 2007, 02:24 AM     #7 (permalink)
Swine flu stopper
Mickwish's Avatar
That's a thought.. maybe using a crossover cable would work? Doubt it, but will try...
Cheers
Mick
Old February 10th, 2007, 02:28 AM     #8 (permalink)
Instigator
You need it to be a straight through cable for connecting PC to router, crossover for connecting one PC to another PC.
Old February 10th, 2007, 02:33 AM     #9 (permalink)
Swine flu stopper
Mickwish's Avatar
I know AR, but I was hoping the crosswired sockets would work with a crossover cable at each end. I tried connecting a x-over cable to each wall socket, then directly to the laptop and router. No difference.
Looks like new sockets...
Cheers
Mick
Old February 10th, 2007, 02:36 AM     #10 (permalink)
Instigator
Wow. It sounds like your all crossed up. Have fun replacing the sockets. Couldn't you just rewire the sockets to the correct configuration?
Wired Network Problems. agnewjamie Networking and Internet 5 January 9th, 2007 06:36 PM
Wired\Wireless Network Connection Problem erethryn Networking and Internet 4 October 26th, 2006 07:34 PM
Creating a wired network Keymaker Networking and Internet 4 November 22nd, 2005 01:38 PM
Wired Network Help! Da-Rock Networking and Internet 8 March 5th, 2004 02:08 AM
Wireless with wired network Zotzmein Networking and Internet 2 May 12th, 2003 10:37 AM
Is It Just Me? (3088)
Foxconn Blackops x48 MoBo (5)
Health Care Rationing (16)
Nvidia GTX 260 problem (13)
Delete an OS (17)
Laptop with wireless problem. (13)
[F@H SPAM 11/16/09] ! 1/2 months to.. (41)
[F@H SPAM 11/16/09] ! 1/2 months to r.. (41)
Print spooler problem (17)
Q9650 vs. Q9550 (2)
soundmon.exe (8)
Jedi Academy Problem (3)
Delete an OS (17)
cheap gaming laptop? (12)
Unallocated Space (2)
C# + LINQ Help (7)
Dynex DX E-402 (3)
