Join TechIMO for Free!
Thread Tools
Currently Active Users: 2271
Discussions: 186,591, Posts: 2,226,870, Members: 230,214
Old June 19th, 2007, 12:49 AM   Digg it!   #1 (permalink)
JohnE.'s Avatar
Send a message via ICQ to JohnE.
Wireless connection to wired router?
Here's the scenario: I have this computer connected to the internet via a wireless router/wireless NIC. I'm using the computers built-in wired NIC to network a second computer via a cross-over cable. Works great, no problems at the moment.
My question is, can I connect a wired router to the onboard NIC in order to network (and give internet access to) more than a single machine, i.e. a third computer? Would I still use the cross-over cable to go to the router and then standard cables to go to the other 2 machines? Currently I have to disconnect the cross-over cable from #2 and plug it into #3 to get access for #3. Internet access for #3 isn't a big concern but it would be nice to have my local network all connected for file transfers, music sharing, etc.
Usually, I would just hook it all up the way I thought it "should" go and hope for the best but since the current setup is working well for 2 machines I wanted to check with others in case there was some detail I missed that would make this not possible. I don't want to mess up my current setup until i have a good idea this can work, heh.
JohnE. is offline   Reply With Quote
FREE instant scan
Old June 19th, 2007, 01:04 AM     #2 (permalink)
Super Stealthy Moderator
RicheemxX's Avatar
How far from the wireless connection is the main pc? and other pc's why not just use wired ports from the original router for those? or does it not have any? Doing it your way you'd be funneling your bandwith through one connection to 3 pcs. With a router and separate connections for each pc you share the bandwith more evenly.
"The true measure of a man is the degree to which he has managed to subjugate his ego."
RicheemxX is online now   Reply With Quote
Old June 19th, 2007, 01:37 AM     #3 (permalink)
JohnE.'s Avatar
Aye, there's the rub... I'm connected to the wireless router through 3 floors of concrete. I've tried the wireless NIC in the other machines and they just can't pick up the signal in their current locations. Only the #1 machine can pick up the signal well enough.
Old June 19th, 2007, 01:54 AM     #4 (permalink)
RicheemxX's Avatar
Ahh I see you are stuck trying something creative. Well someone with a little more knowledge on ICS might have to correct me on this one.
But as far as I know all you'd need to do is Disabled DHCP on the router and plugged the crossover cable into a LAN port instead of its WAN port you might have to Allocate each PC a static IP. But then yeah enable ICS in the host run the networking wizard to set up ICS and you should be set.
Old June 19th, 2007, 02:28 AM     #5 (permalink)
JohnE.'s Avatar
Ok, I'll give it a try.. worst that can happen is I won't have a home network for a while if it doesn't work. Hope those aren't "famous last words", hehe.
Old June 19th, 2007, 02:29 AM     #6 (permalink)
Onii-san
Bizkitkid2001's Avatar
All you have to do is set the router to work as a standard switchm or just ditch the router and buy a switch.
Bizkitkid2001 is offline   Reply With Quote
Old June 23rd, 2007, 06:09 PM     #7 (permalink)
JohnE.'s Avatar
I finally found the time to tackle this today and it's all good, thanks for the input guys.
I tried several possible configurations of cross-over and standard network cables and WAN/LAN ports and what ended up working, after I disabled DHCP on the wired router, used the Network Setup Wizard several times and disabled the Windows Firewall on all machines, was: standard cable from the #1 computer's (the one with the wireless connection to the internet) onboard NIC to #7 LAN port (not the WAN port) on the wired router, then standard cables from the other 3 machines to remaining LAN ports on the wired router. Full home network and internet connectivity on all machines.
Yay, no more cable swapping or CD-RW burning to move files 5 feet over. It would have been easier with a hub I'll bet, but I couldn't find the darn thing.
Old June 23rd, 2007, 06:40 PM     #8 (permalink)
Onii-san
All of the big name brand router companies (Linksys, Netgear, D-Link) have instructions on their website on how to do exactly what you did. When I posted my first reply I forgot that it was the Linksys website where I learned how to do that with my wired and wireless router.
Old June 23rd, 2007, 06:55 PM     #9 (permalink)
Send a message via AIM to RamonGTP Send a message via Yahoo to RamonGTP
http://www.newegg.com/Product/Produc...82E16833162168
That's what you need... This will connect to the wireless router that's three floors away and has a built in 4 port switch. You can plug your wired computers into it instead of having to piggy back to your laptop. This way your laptop can remain portable while the wired computers have their own connection via the Buffalo Ethernet Converter.
It's very easy to setup, i've used these on three seperate occassions and they are very stable.
RamonGTP is offline   Reply With Quote
Old June 27th, 2007, 08:12 PM     #10 (permalink)
JohnE.'s Avatar
Well, I spoke too soon... as soon as I rebooted the ICS host machine my network disappeared and I had no internet connection on any of the machines connected to the router. No amount of cable swapping and Network Setup Wizarding has got this working again. For some reason the router keeps re-enabling DHCP no matter how many times I disable it (and save and reboot the router each time).
What boggles my mind is that it worked perfectly until I rebooted the host machine.. argh. I had to go back to a single shared connection via NIC>crossover cable>NIC but I'm going to try this again and try assigning static IP's in the routers config.
On the plus side, my walk-in closet is getting a good cleaning while I hunt for that old hub, lol.
Thread Tools
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Running a wireless router off a port on a wired router. LeftCoast Networking and Internet 4 October 17th, 2005 01:21 PM
Wired Linksys Router not Connection mldapril17 Networking and Internet 2 June 2nd, 2005 12:54 AM
Wired and wireless connection question. RAR Networking and Internet 2 January 11th, 2005 09:27 AM
Adding a wireless router through a hub and wired router to my DSL jbgdvc Networking and Internet 1 June 17th, 2004 04:50 PM
Wireless Router To Wired Router (Trying to Make a Switch) w12plai Networking and Internet 2 January 25th, 2004 01:22 PM
heatsink issue (8)
Is It Just Me? (492)
Why Does the MOON Grow Bigger as It.. (11)
New Mobo (16)
1 internet. 1 house. 3 computer. ho.. (10)
Connected to LAN but unable to use .. (5)
heatsink issue (8)
Hard Core Overclock (7)
FS: New Benny Hill Megaset DVD .. (6)
Computer won't start (2)
New Mobo (16)
1 internet. 1 house. 3 computer.. (10)
Request for recovary system ins.. (0)
Folderchat: The Holiday thread (111)
am2 on 939 (4)
Folderchat Weekday thread (411)
